complete exhaust system
cb1300rider
cb1300rider
Post by cb1300rider on Mon 25 Jul 2011, 7:43 pm
Howdy
Im going to be needing to replace my exhaust soon, headers and end can, anyone got any advise on the best way to remove the header pipes?
I didnt have the best experience with header pipe removal on my ntv600 i had previously.
So if anyone has experience of this and some good tips i would appreciate it.
Thanks in advance
Simon
steeeve66
steeeve66
Re: complete exhaust system
Post by steeeve66 on Mon 25 Jul 2011, 8:00 pm
Removing the header pipes is pretty straightforward - the only likely problem will be the studs securing the pipes to the front of the engine; they'll probably be corroded and seized, so spray some wd40 on them and leave for a while, it's not the end of the world if you strip them, they are replaceable, but it's a pain so go easy on them.
The end can really shouldn't present any trouble tho.
Slippery2009
Slippery2009
Post by Slippery2009 on Thu 04 Aug 2011, 2:30 pm
If I were you I'd take the opportunity to replace the studs as well. They are very cheap and if there's signs of rust on them whip em out. It's a straight forward double nut job providing you don't snap any removing the header. Liberal lubrication is recommended!
spitonyourgrave22
spitonyourgrave22
Post by spitonyourgrave22 on Mon 08 Aug 2011, 3:00 pm
It's for this reason exactly that I always rubbed them in WD40.
The headers are pretty easyto remove and replace. The biggest problem I ever had with my exhaust was securing the clamp that links them. You have to do that up TIGHT
    Current date/time is Sun 24 Mar 2019, 7:22 pm
