fork swap on cb500
Gonzumzum
Gonzumzum
Re: fork swap on cb500
Post by Gonzumzum on Tue 22 Apr 2014, 1:45 pm
pics?
Post by ANDYC on Tue 22 Apr 2014, 8:22 pm
@badseeds wrote:Whole front end? Andy, maybe you should be a club technical adviser as you do seem to know your onions with these bikes and as a courier, your opinion is worth a bit more :-)
Praise indeed, I'm very flattered Laughing
Mad_Taffy_500
Mad_Taffy_500
Post by Mad_Taffy_500 on Wed 08 Aug 2018, 3:29 pm
I know this is a old topic but when doing the fork swap how would you go about keeping the headlight and clocks as the cbr600 use a different mounting system to the Cb
Post by ANDYC on Wed 08 Aug 2018, 10:39 pm
Mine was the faired S model so I didn't have to worry about that problem.
Mad_Taffy_500
Mad_Taffy_500
Post by Mad_Taffy_500 on Wed 08 Aug 2018, 10:59 pm
I see due to having the bracket on the headstock tube
So this is something I'm going have to look in to myself then
Post by Jameshambleton on Thu 09 Aug 2018, 9:43 am
You can just buy headlight brackets loads to choose from on ebay ect
Mad_Taffy_500
Mad_Taffy_500
Post by Mad_Taffy_500 on Thu 09 Aug 2018, 11:39 am
I've seen them before I knew I might need one but still got to solve the clock bracket out as there would be no mounting point for it on the yokes I would think
Post by ANDYC on Thu 09 Aug 2018, 6:25 pm
Just make some brackets to bolt to the underside of the top yoke.
Do you have any particular forks in mind?
I actually have my vfr750 ones with yokes available. As well as the front wheel.
Mad_Taffy_500
Mad_Taffy_500
Post by Mad_Taffy_500 on Thu 09 Aug 2018, 8:02 pm
I hadn't yet as just doing more research 1st
But want something with more adjustment
    Current date/time is Sun 24 Mar 2019, 7:02 pm
