Are the footrest hangers the same across models (say 1994 and 1998?)
frggr
frggr
Are the footrest hangers the same across models (say 1994 and 1998?) Empty Are the footrest hangers the same across models (say 1994 and 1998?)
Post by frggr on Fri 02 Aug 2019, 7:50 pm
I ask because I need a replacement, but can't find the exact model number for my 1998.
There's one for 1995 that looks the same in the diagram, but has a different model number. I assume the only real changes were cosmetic (and brakes etc), but that the frame design stayed largely the same. Would this be right?
I'm in a bit of a pickle in a foreign country and missing a footrest hanger that can't be repaired, so any advice would be greatly appreciated!
Thanks  Very Happy
Are the footrest hangers the same across models (say 1994 and 1998?) Empty Re: Are the footrest hangers the same across models (say 1994 and 1998?)
Post by ANDYC on Fri 02 Aug 2019, 8:37 pm
I believe that they are the same.
Post by muttley1 on Fri 02 Aug 2019, 10:08 pm
Yes, all the same.
I've bought, all by online shopping over the years, footrests from hein gericke, Busters and from bertrams bike bits. All have stated that they fit the cb500, all didn't. I filed the hein g ones a bit and they are ok, the other sets went back and both were "lost" by the original seller. I got one gpo refund but moral of the story, its a lottery and sellers aren't that bothered.
Post by Beresford on Sat 03 Aug 2019, 9:51 am
The RHS is different for drum and disc rear brake. The footpegs are the same though.
frggr
frggr
Post by frggr on Sat 03 Aug 2019, 12:02 pm
@Beresford wrote:The RHS is different for drum and disc rear brake. The footpegs are the same though.
Ahhhh - what's the difference? I've got a disc, but I think the hanger is from a drum.
frggr
frggr
Post by frggr on Sat 03 Aug 2019, 12:09 pm
@muttley1 wrote:Yes, all the same.
Ah, I'm referring to the actual bracket the footrest attaches to, not the footrest itself.
It seems to be a common problem because there are a lot of LHS brackets, but not many RHS brackets available.
Post by Beresford on Sat 03 Aug 2019, 9:37 pm
I haven't studied a drum hanger, but there is no easy way to change one to t'other as the disc one has the slave cylinder to deal with.
The LHS hangers are the same throughout, which is why they are more readily available. Also, the Racers hoover up parts which is inconvenient for us road bikers.
frggr
frggr
Post by frggr on Sun 04 Aug 2019, 2:25 pm
Strange. The image I'm seeing of the RHS hanger has the slot for the slave cylinder, it seems.
But looking more closely, I can see what you mean. There's no hole to mount the return spring (though the boss is there, so it can be drilled) and there's no mount/rotation point for the pedal itself - some modification could make that work though.
Slave cylinder mounts at two points. There's a hole for one in the older style RHS bracket, but another could be drilled out.
Everything else is the same/similar.
    Current date/time is Wed 21 Aug 2019, 7:36 pm
