Annoying throttle twistgrip issue
Annoying throttle twistgrip issue Empty Annoying throttle twistgrip issue
Post by jchesshyre on Fri 28 Jun 2019, 10:40 am
My twistgrip is rubbing in a really annoying way – there doesn't seem to be quite enough space between the bar end weight and the switchgear. I tried having the weight a bit looser (has thread-lock on so won't come undone) but it vibrated in a nasty way.
I never had this with my first CB so I don't know why this would be like this. It's not an aftermarket grip as far as I can see.
Any tricks to sort this? I *really* hate the feeling of a stiff throttle...not to mention safety and MoT...
J0a
J0a
Annoying throttle twistgrip issue Empty Re: Annoying throttle twistgrip issue
Post by J0a on Fri 28 Jun 2019, 3:34 pm
I just added a plastic/rubber washer/piece in between to get the bar end weight further out and not touch my throttle grip anymore.
Post by Beresford on Fri 28 Jun 2019, 11:01 pm
I just eased the grip rubber away from the BEW and put in the occasional squirt of WD40. Usually only needs to be repeated every couple of weeks.
Post by jchesshyre on Sat 29 Jun 2019, 1:32 pm
@J0a wrote:I just added a plastic/rubber washer/piece in between to get the bar end weight further out and not touch my throttle grip anymore.
Cheers lads, well I had some spare 10p-sized plastic washers lying around – a couple of these has completely sorted it. For someone with a fair bit of experience working on bikes, I'm quite unimaginative sometimes...
    Current date/time is Tue 23 Jul 2019, 6:11 am
