Hagon fork springs, upping the oil?
Hagon fork springs, upping the oil? Empty Hagon fork springs, upping the oil?
Post by muttley1 on Tue 25 Jun 2019, 2:34 pm
I'll be changing my fork oil pretty soon and have hagon springs. Apart from being fitted "wrong way" up to oe ones as standard they have 7.5w oil, which I find a bit bouncy. Anyone tried 10 or 15w oil?
wrighty
wrighty
Hagon fork springs, upping the oil? Empty Re: Hagon fork springs, upping the oil?
Post by wrighty on Tue 25 Jun 2019, 5:54 pm
I believe 10w is standard. I considered changing to 15w but was advised upping the weight will slow the forks ability to react to either compression or rebound. A better way to stiffen up forks without slowing reaction is to fit spacers in fork tops, effectively preloading the fork springs.
Post by liverpool_f_ on Tue 25 Jun 2019, 8:54 pm
If you are doing the forks at home, how are you going to support the bike at the front?
Post by muttley1 on Tue 25 Jun 2019, 9:43 pm
Cheers Wrighty,
The Hagons come with a litre of 7.5w and that's what they recommend for the cb5 too. I reckon going for 10w is worth a try as the 7.5w gives a bit of an underdamped feel. If its not a winner then spacers it is.
Liverpool F, I put the bike on a rear paddock stand, add a couple of chocks to stop the bike rolling, then put the bike on a front paddock stand. I've a car jack that goes under the sump that takes the weight off the front. I also put a couple of axle stands under the hangers in case of a clumsy moment.
I put a couple of planks under the front wheel so it is just supported, makes getting the axle etc out.
cheers
    Current date/time is Wed 21 Aug 2019, 6:57 pm
