Location Grouping
birdyboy
birdyboy
Solved Location Grouping
Post by birdyboy on Sun 22 May 2011, 21:54
Is there a way through the site that we can add ourselves to a region/location mapper in order to be able to advertise to other CB owners in our area of possible ride outs? Would make it easier to target those people close enough to make a meeting point?
Solved Re: Location Grouping
Post by teamster1975 on Sun 22 May 2011, 23:01
That you can! Take a look at this page.
Last edited by teamster1975 on Sat 19 Apr 2014, 19:00; edited 1 time in total (Reason for editing : Fixed link)
birdyboy
birdyboy
Post by birdyboy on Mon 23 May 2011, 21:53
Great = thanks. I think I managed it.....
freeride
freeride
Laser Shark
Laser Shark
Post by freeride on Tue 24 May 2011, 21:46
Birdyboy,
Not sure if you've seen my post for the Eastern region on the Meets/Rideouts section? Are you still on for the September run?
BC3841
BC3841
Post by BC3841 on Sat 19 Apr 2014, 15:20
When I open the website initially, everything displays OK but within a split second, all the print flips over to the right and everything on the right hand side is then cut off. How do I avoid this happening?
Post by teamster1975 on Sat 19 Apr 2014, 19:01
@BC3841 wrote:When I open the website initially, everything displays OK but within a split second, all the print flips over to the right and everything on the right hand side is then cut off. How do I avoid this happening?
I've just fixed the link, it was pointing to the old domain. Can you try it again? I just loaded it up fine in IE11 Smile
BC3841
BC3841
Post by BC3841 on Sat 19 Apr 2014, 20:42
Hello teamster1975, I can read your message because it's shorter than a line, but all the other messages, including my own, have a few words at the right hand end cut off.
Post by teamster1975 on Sun 20 Apr 2014, 12:03
What browser are you using?
BC3841
BC3841
Post by BC3841 on Sun 20 Apr 2014, 14:57
I'm using Opera. I've just tried Internet Explorer and it's OK with that. It appears it's a Opera browser fault then.
Post by teamster1975 on Sun 20 Apr 2014, 16:18
@BC3841 wrote:I'm using Opera. I've just tried Internet Explorer and it's OK with that. It appears it's a Opera browser fault then.
It must be the way the frames are rendered; I've not used Opera myself, tested ok with Chrome and Firefox. Sorry about that!
BC3841
BC3841
Post by BC3841 on Mon 21 Apr 2014, 10:26
That's OK, not to worry.
stevew
stevew
Post by stevew on Fri 14 Nov 2014, 22:55
Would it be possible to put our rough location on our posts, on the left where the avatar is?
Would help if anyone needed techy advice if the knowledgeable one was close by.
Also when selling/buying stuff it would be useful.
Just a thought Very Happy
Post by Tricky. on Sat 15 Nov 2014, 01:02
@stevew wrote:Would it be possible to put our rough location on our posts, on the left where the avatar is?
^ good post.
Post by eternally_troubled on Sat 15 Nov 2014, 14:22
^ good post.
There is probably a way of doing this.  I'm pretty sure that there is a 'location' field in everyones profile.
I don't have the permissions to do it, but I bet there is a way of getting it displayed along with your avatar/username.
Post by teamster1975 on Sat 15 Nov 2014, 18:51
@eternally_troubled wrote:I don't have the permissions to do it, but I bet there is a way of getting it displayed along with your avatar/username.
I had a look at this earlier, no you cannot display the location field in posts. I'll hack through the help forums to see if it can be added as a custom field, I would have thought it's possible and it is a good idea!
stevew
stevew
Post by stevew on Sat 15 Nov 2014, 18:58
If it can't be done as you suggest, what about using the signature facility?
Post by teamster1975 on Sat 15 Nov 2014, 19:13
@stevew wrote:If it can't be done as you suggest, what about using the signature facility?
Yes that would work although PHPBB allows showing location so I cannot see why forumotion won't Smile
stevew
stevew
Post by stevew on Sat 15 Nov 2014, 19:17
I'm assuming sig is disabled ATM?
Post by teamster1975 on Sat 15 Nov 2014, 19:18
@stevew wrote:I'm assuming sig is disabled ATM?
Sussed location Wink Forumotion is convoluted!
stevew
stevew
Post by stevew on Sat 15 Nov 2014, 19:19
Brill, can you do the sig as well or do you want to keep the posts "clean" ?
Post by teamster1975 on Sat 15 Nov 2014, 19:21
@stevew wrote:Brill, can you do the sig as well or do you want to keep the posts "clean" ?
Just looking now. It's enabled but not showing! Don't worry, I'll crack it Wink
Post by teamster1975 on Sat 15 Nov 2014, 19:26
test
Post by teamster1975 on Sat 15 Nov 2014, 19:27
Signature will appear on any messages created from now on Smile
stevew
stevew
Post by stevew on Sat 15 Nov 2014, 19:30
What a cracking lad you are !!!!
Thanks Very Happy Very Happy Very Happy
Post by teamster1975 on Sat 15 Nov 2014, 19:33
@stevew wrote:What a cracking lad you are !!!!
Damned decent of you Steve! Very Happy
I'm having a celebratory Hob Goblin!
    Current date/time is Wed 20 Feb 2019, 18:25
