Valve stem seals
The Hurricane
The Hurricane
Valve stem seals Empty Valve stem seals
Post by The Hurricane on Sat 25 May 2019, 1:49 am
I have bought some new valve stem seals and looking a bit closer they are a slightly different colour. 4 are green and the other 4 are a bit darker shade of green. I then checked the old one's and they are the same.
So which 4 are the inlets and which are the exhaust valve stem seals.
Checking with a vernia, I can only see that the height is the only difference and that is only .25mm?
Crash- Elmit
Crash- Elmit
Valve stem seals Empty Re: Valve stem seals
Post by Crash- Elmit on Sat 25 May 2019, 2:25 am
check the internal diameter. exhaust valve stem is smaller diameter than inlet
inlet 4.475--4.490
exhaust 4.465--4.480
The Hurricane
The Hurricane
Post by The Hurricane on Sat 25 May 2019, 4:31 am
Thank you for your help. Much appreciated.
Post by ANDYC on Sat 25 May 2019, 5:52 am
They are interchangeable, realistically a hundredth of a millimetre is going to make no difference at all.
The Hurricane
The Hurricane
Post by The Hurricane on Sat 25 May 2019, 7:51 am
Cheers, Thank you.
    Current date/time is Sun 22 Sep 2019, 11:08 pm
