cylinder head bolts
The Hurricane
The Hurricane
cylinder head bolts Empty cylinder head bolts
Post by The Hurricane on Thu 16 May 2019, 8:00 pm
There are two bolts in the cylinder head with allen key flat heads. They sit each side of the cam chain tunnel.
Just wondering what are they for, as I can't see without taking them out and didn't want to disturb them without knowing?
cylinder head bolts Empty Re: cylinder head bolts
Post by ANDYC on Thu 16 May 2019, 8:30 pm
If you're looking at the large Allen type socket things that look like grub screws sitting flush-ish then you don't need to touch them.
I believe that they are blanking the holes that were used for cores for the water jacket in the initial casting process.
The Hurricane
The Hurricane
Post by The Hurricane on Fri 17 May 2019, 10:59 pm
Cheers, Thank you.
    Current date/time is Mon 27 May 2019, 6:16 am
