Rear wheelbearing broke up
Rear wheelbearing broke up Empty Rear wheelbearing broke up
Post by wornsprokets on Thu 16 May 2019, 12:41 am
Well had lucky one on monday evening rear wheel bearing broke up on motorway. I managed to get bike home through back roads at 20mph. Bearings were not that old i think they were kyo (did i spell that right) as i have cb 500 v and cb500s not sure... As i changed all  wheel bearings in both bikes... In last couple years. I have to check my ebay history.
burudis
burudis
Rear wheelbearing broke up Empty t
Post by burudis on Sun 19 May 2019, 6:18 pm
take the opportunity to change the two.
very easy with the manual in hand
Rear wheelbearing broke up Empty Re: Rear wheelbearing broke up
Post by wornsprokets on Tue 21 May 2019, 10:56 pm
Only change bearings few year ago ... Very poor bearings becareful what bearings you buy only buy jap madebearings
Post by wornsprokets on Thu 23 May 2019, 11:52 pm
Well took wheel out sprocket bearing broke up also wheel bearing nearest to sproket.. Broke up to bits also use bearing puller to get remains of bearings out
Crash- Elmit
Crash- Elmit
Post by Crash- Elmit on Thu 23 May 2019, 11:59 pm
@wornsprokets wrote:Well took wheel out sprocket bearing broke up also wheel bearing nearest to sproket.. Broke up to bits also use bearing puller to get remains of bearings out
Did you have your chain tension set wrong? for them to go like that on same side suggests too much uneven tension on the sprocket bearings
    Current date/time is Mon 23 Sep 2019, 3:05 pm
