CB500S2 No power
GGG267
GGG267
CB500S2 No power Empty CB500S2 No power
Post by GGG267 on Sun 21 Apr 2019, 8:17 pm
My bike has been in the shed over winter, tried the ignition switch nothing, checked the battery voltage and seems ok
Any ideas anyone ?
Glenn
CB500S2 No power Empty Re: CB500S2 No power
Post by geewhizz on Sun 21 Apr 2019, 9:06 pm
maybe try giving it a small push back and forth then hit the starter again. sounds silly but its not in gear and the kill switch is in the right position?
GGG267
GGG267
Post by GGG267 on Sun 21 Apr 2019, 9:14 pm
I am getting no indication on the dash
GGG267
GGG267
Post by GGG267 on Sun 21 Apr 2019, 9:20 pm
Could it be the key switch ? No Key switch Ok
GGG267
GGG267
Post by GGG267 on Mon 22 Apr 2019, 5:21 pm
30 Amp fuse blown, changed the fuse bike started ok but then smoke came out of the Regulator needs further investigation
Bike did run for about 10 mins no problem
GGG267
GGG267
Post by GGG267 on Mon 22 Apr 2019, 9:53 pm
Burnt contact on rectifier on red / white stripped cable terminal, any ideas of the cause
    Current date/time is Thu 27 Jun 2019, 5:31 am
