Front brake master cylinder rubber
davecb5002
davecb5002
Laser Shark
Laser Shark
Front brake master cylinder rubber Empty Front brake master cylinder rubber
Post by davecb5002 on Sun 14 Apr 2019, 7:41 pm
Brembo master cylinder, has a rubber dust cover on end of pushrod. Mine has split and in bits. Any ideas on what could be used, the Honda part number is 45504MAK 003. Rubber dust boot. But is over £9 plus postage  Shocked Shocked. So any ideas of a substitute would be much appreciated Smile Smile
davecb5002
davecb5002
Laser Shark
Laser Shark
Front brake master cylinder rubber Empty Re: Front brake master cylinder rubber
Post by davecb5002 on Wed 17 Apr 2019, 7:28 pm
Got this sorted used an old rubber plug cap, the end that takes the HT lead. Cut a piece  off and fitted perfect  Smile Smile Think the price of genuine Brembo one was silly affraid But sorted now.
Post by muttley1 on Thu 18 Apr 2019, 10:57 pm
Iirc the price of the master cylinder kit with spring, circlip, piston and rubber boot is about £27. Does make the brake feel better.
Btw, if anyone is having the mystery "lever going all the way back to the bar" thing, despite clean fluid and no leaks...its because you've the wrong brake lever fitted. The difference between the levers for Nissin and Brembo master cylinders is small but causes the above.
    Current date/time is Sun 21 Apr 2019, 11:24 pm
