Universal Speedometer wiring - need help
jpborges
jpborges
Universal Speedometer wiring - need help Empty Universal Speedometer wiring - need help
Post by jpborges on Sat 30 Mar 2019, 12:52 am
Hello,
I'm replacing the original dash with a smaller one, but I've some doubts regarding the connections.
Can someone help me?
The wiring diagram for the speedometer is the one bellow.
Universal Speedometer wiring - need help Img_2010
Acording to the CB 500 wiring diagram the wiring should be the one bellow, am I right or not seeing the all picture?
Universal Speedo    Honda Wire diagram
PurpleRed with green stripe
OrangeOrange
Light BlueLight Blue
GrayBlue with red stripe
Dark Brown (RPM)Yellow with green stripe
YellowDark Blue
RedRed
BlackGreen
BrownBlack with brown stripe
Should this be the wiring equivalent?
Thank you in advance.
Regards
Universal Speedometer wiring - need help Empty Re: Universal Speedometer wiring - need help
Post by liverpool_f_ on Sun 31 Mar 2019, 10:29 am
Perhaps you have a newer cb500 than ours? The ones we have all have cable driven mechanical speedos.
wrighty
wrighty
Post by wrighty on Sun 31 Mar 2019, 11:47 am
Is that a Koso instrument? If you hit the search tab at top of page and enter "koso wiring", you'll find 'Eternally_troubled' posted a chart with the correct wiring. It was really useful to me with my Koso clock and everything worked perfectly. (Many thanks ET)
Post by Jameshambleton on Sun 31 Mar 2019, 11:56 am
@liverpool_f_ wrote:Perhaps you have a newer cb500 than ours? The ones we have all have cable driven mechanical speedos.
Speedo on Koso and aftermarket clocks take a magnetic reading from the front wheel the same as a bicycle speedo.
http://www.cb500club.net/t5543p50-jameshambleton-87-vfr750-liz#57341
jpborges
jpborges
Post by jpborges on Sun 31 Mar 2019, 12:40 pm
Hello,
No my CB is not diferent of yours, it as a cable, as Jameshambleton stated the aftermarket speedos have magnetic reading, that part is easy, my doubt is what cables should be connected.
This is not a Koso it is an universal one from Louis.de, bellow is the link for the item.
https://www.louis.eu/artikel/t-t-multifunction-instrument/10034806
Regards
    Current date/time is Mon 23 Sep 2019, 2:53 pm
