torque arm bolt on drum CB
LI
LI
torque arm bolt on drum CB Empty torque arm bolt on drum CB
Post by LI on Mon 14 Jan 2019, 2:22 pm
I've had my CB from new, it's 23 this year.  Just had the swing arm powder coated by Triple S in Bingley.  I can't recommend them highly enough.  Anyway, putting the bike back together yesterday, one thing I've always struggled with is the order of the washers on the torque arm where it attaches to the drum.  Currently its drum, torque arm, rubber washer, metal washer, nut.  But I always wondered if the rubber washer should be between the drum and the torque arm as I can't see the point of it?  Haynes is no help here and neither are online schematics which don't show where the arm fits in the order.
Anyone know what the correct order is?
cheers,
Li
wrighty
wrighty
torque arm bolt on drum CB Empty Re: torque arm bolt on drum CB
Post by wrighty on Mon 14 Jan 2019, 4:19 pm
Hi Li, you have the order correct. Bolt inserts from rear of backplate, ensuring bolt head locates in recess, then it's torque arm, rubber bush, washer and nut. If my pictures come out clear enough you can see picture 16.3b at top of page and instructions in para 15 of next page.torque arm bolt on drum CB 20190110
LI
LI
Post by LI on Mon 14 Jan 2019, 5:28 pm
Thanks for that. Not sure how I missed that, but it doesn't explain why the rubber bush is there?
Post by ANDYC on Mon 14 Jan 2019, 7:42 pm
Triple S are very good but very expensive especially if you have to rely on the post. A flat rate of £25 to post anything back to you!
I have used them for many years but can't justify the cost now so I'm in search of somewhere more local to me.
    Current date/time is Mon 22 Jul 2019, 10:39 pm
