JIS screwdrivers
JIS screwdrivers
Post by geewhizz on Tue 08 Jan 2019, 7:53 pm
I’m in need of new screwdrivers so thought I did give the JIS drivers a go. Anyone’s here use them? I believe they may be better suited to the standard fasteners found on our machines.
In particular this Vessel megadora set on eBay is tempting. Any thoughts? https://www.ebay.co.uk/itm/Vessel-Megadora-900-P1x75-P2x100-P2x150-JIS-Cross-Point-Screwdriver-Set-Japan/253240046857?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Re: JIS screwdrivers
Post by Jameshambleton on Tue 08 Jan 2019, 8:25 pm
You only need the .150 one.
They are 100% worth the money because they ARE the correct tool for the fasteners unlike pz and philips screwdrivers.
I've personally got the Vessel .150 it's my go to tool
Post by geewhizz on Tue 08 Jan 2019, 8:33 pm
do you not need the P1 for the smaller fasteners on the carbs for example?
Post by Jameshambleton on Tue 08 Jan 2019, 9:06 pm
Not sure which you mean by the smaller fasteners in the carbs but I've just removed one of the screws holding the throttle butterfly in place without a problem
hh_12345
hh_12345
Post by hh_12345 on Tue 08 Jan 2019, 9:08 pm
Here's some info on JIS screws:
http://www.dansmc.com/jis_screw.htm
I am usually using 1/4" bits with a screwdriver handle, ratchet or the  impact screwdriver I recently got (very useful).
Post by geewhizz on Tue 08 Jan 2019, 9:24 pm
I was referring to the various assembly’s bolts /screws for the carbs. Was just guessing that they would take a smaller driver. I did take them apart a while ago, unfortunately too long ago to remember what tools I used.
GollyGosh
GollyGosh
Post by GollyGosh on Tue 08 Jan 2019, 11:45 pm
@Jameshambleton wrote:You only need the .150 one.
if you want just the one...
P2 150 on Amazon
Post by geewhizz on Wed 09 Jan 2019, 7:34 am
Great spot gollygosh, thank you. Ive just ordered it Laughing
GollyGosh
GollyGosh
Post by GollyGosh on Wed 09 Jan 2019, 4:12 pm
@geewhizz wrote:Great spot gollygosh, thank you. Ive just ordered it Laughing
You're very welcome Cool
If you read the armchairbiker link in the E10 petrol discussion, he said
"I bit the bullet, cursed my perpetual failure to buy JIS screwdrivers and opened the carbs."
So there will be no cursing when tackling your carbs  Very Happy
dv12
dv12
Post by dv12 on Thu 17 Jan 2019, 12:03 am
+1 for JIS screwdrivers. The fit is so much better.
I got the Bessel-(Vessel) interchangeable type. I normally hate interchangeable screwdriver nonsense but that tool is genuinely brilliant.
The p2 and the flat head on are the same shank. Very handy. The flat also has no taper so it sits right down into a slot head. Good for pilot jets etc.
motofan
motofan
Post by motofan on Fri 18 Jan 2019, 10:29 am
I got the three, #2 is the most useful but I use the #3 where it fits in big screws and it removes/tightens without any of the damage associated with using Philips drivers. I think that Japanese screws got such a bad reputation for being soft because in the 60s nobody had JIS drivers and used Philips #2 points which butchered the screw heads! A Philips #3 works fine but who has one of them?
I even bought the silver impact pair though I've yet to need them!
Buy good tools once, buy bad tools twice!
motofan
motofan
Post by motofan on Fri 18 Jan 2019, 10:44 am
These are good, I have the number two point and it's more comfortable than the blue ones also you can apply more pressure with it.
https://www.ebay.co.uk/itm/Vessel-220-Ball-Grip-P1x75-P2x100-JIS-Cross-Point-Screwdriver-Set-Japan-Driver/263751167194?epid=6020305640&hash=item3d68cb6cda:g:CK8AAOSwQolbHjog:rk:13🇵🇫0
Crash- Elmit
Crash- Elmit
Post by Crash- Elmit on Fri 25 Jan 2019, 5:00 am
my set arrived today. they certainly look the business
Post by ceejay on Fri 25 Jan 2019, 11:09 am
Just to jump on the JIS bandwagon, I have had the set of 3 linked in the original post for years and can confirm they make more of a difference compared to a 'normal' screwdriver than you would ever think they could by looking at them! They have saved me from cutting/grinding out many screw heads!
Post by sullivj on Sat 26 Jan 2019, 12:58 am
My set of 3 arrived today.
Thanks for the tip.
Post by stormbringer on Sat 26 Jan 2019, 4:50 pm
Never knew this. Mucho interesting!
    Current date/time is Wed 20 Mar 2019, 1:08 pm
