Rectifier location
shropshirewildman
shropshirewildman
Rectifier location
Post by shropshirewildman on Sat 05 Jan 2019, 11:54 am
I've fitted fireblade coils to my bike, I now have a big space where the old ones were. Does anyone think that this would be ok to relocate the rectifier to this space better ventilation etc  my year old rectifier has died again.
Re: Rectifier location
Post by Jameshambleton on Sat 05 Jan 2019, 5:59 pm
I did this with my mosfet even though it didn't need the additional cooling
Post by eternally_troubled on Sat 05 Jan 2019, 7:25 pm
Should be fine. You just need to make sure you use suitably thick cable and do the joints/insulation properly.
Post by jerryfudd on Sat 05 Jan 2019, 7:50 pm
'blade parts. ... gotta be atleast 50hp in that.
in all seriousness though any details?
shropshirewildman
shropshirewildman
Post by shropshirewildman on Sat 05 Jan 2019, 10:59 pm
Thanks all, yes R1 MOSFET rectifier, thick cable, joints soldered, wired direct to battery and up front in the breeze im hoping that sorts it. All info on fireblade coils in the upgrade section, well worth it picks up much stronger.
burudis
burudis
Post by burudis on Sun 06 Jan 2019, 5:46 pm
shindengen regul-rectifier mosfet dont need more cooling.
Post by Beresford on Sun 06 Jan 2019, 9:03 pm
@burudis wrote:shindengen regul-rectifier mosfet dont need more cooling.
As long as it is a series type, not shunt
Post by eternally_troubled on Sun 06 Jan 2019, 9:28 pm
It won't do any harm...
burudis
burudis
Post by burudis on Mon 07 Jan 2019, 5:16 pm
shindengen japan the best.
Chinese mosfet shindengen is shunt always.
Everyone will sell you Chinese.
the best for my:
http://www.hondahornet.org.uk/messageboard/viewtopic.php?f=9&t=24110
Shindengen "F"= mosfet type
FH012AA ok and the last FH020AA.
Today used -japan- by triumph, 4 japan, bmw, ducati etc
usual price used ebay etc 80-100€.
low price=china.
new connector type les expensive at aliexpress.
Post by Beresford on Mon 07 Jan 2019, 10:24 pm
The SH775 Series R/R from Shindengen can be sourced from Polaris dealers at about £70. It is only suitable for engines which rev to about 10000rpm. Above that there is a later Shindengen series type, the SH847AA which is more expensive. It was first used on some Suzuki models in 2014.
burudis
burudis
Post by burudis on Tue 08 Jan 2019, 6:32 pm
also ok electrexworld
shropshirewildman
shropshirewildman
Post by shropshirewildman on Fri 08 Feb 2019, 2:10 pm
Ok so a fh020aa sourced (cbr500) I need 60amp wire for positive (with an inline fuse) and negative but what rating wire for the three yellow wires from stator to the rectifier, do I need 60 amp for these too?
burudis
burudis
Post by burudis on Fri 08 Feb 2019, 6:33 pm
always original wires ok.
Last CB500 come with shindengen F type mentioned.
    Current date/time is Wed 20 Mar 2019, 1:16 pm
