5w 30
5w 30 Empty 5w 30
Post by muttley1 on Wed 12 Dec 2018, 7:57 pm
one of my cb5's has always had 5w30 oil, its now at 44k and runs well on it. I did see cheap oil in Home Bargains of all places, £15.99 for 4l. Its fully synthetic. I'm tempted to go with this over the usual Hein Gericke 10w 40 semi synthetic.
What do folks reckon?
5w 30 Empty Re: 5w 30
Post by Beresford on Wed 12 Dec 2018, 8:07 pm
I've laid in a few containers of the Home Bargains offer synthetic 5W30 for use at normal UK (and Ireland!)  temperatures . If we had a heatwave I'd be looking for something else in the 10W40 range
Post by muttley1 on Wed 12 Dec 2018, 8:11 pm
Cheers,
no heatwaves on the horizon. My 5w30 bike does start more easily than the other but when they are on the move no difference in engine performance.
I'll drop by HB tomorrow and get a couple of containers.
kungfupoodle
kungfupoodle
Post by kungfupoodle on Tue 18 Dec 2018, 8:44 am
I'm all in favour of having the Winter number as low as possible (5W or 0W) as it flows better when cold.
burudis
burudis
Post by burudis on Tue 18 Dec 2018, 12:27 pm
always use 5W30 car liquimoly top tec 4200
30 years with not slipping clutch
bviep
bviep
Post by bviep on Thu 20 Dec 2018, 8:38 pm
I’m using Motul 7100 5W30, it shifts gears better then 10W40 I’ve used
Post by muttley1 on Wed 09 Jan 2019, 5:24 pm
Halfords have an offer on Castrol Magnatec, £17 for 4litres. Picked one up for the car, might well get another in for the bike.
Post by Jameshambleton on Wed 09 Jan 2019, 8:11 pm
@muttley1 wrote:Halfords have an offer on Castrol Magnatec, £17 for 4litres. Picked one up for the car, might well get another in for the bike.
Pretty decent price, their trade price is only £16.50 for it
Post by geewhizz on Wed 09 Jan 2019, 9:53 pm
Hmm... which one should we buy? 5w30 A5, or C3, or the 10w40 A3?
Post by jchesshyre on Thu 10 Jan 2019, 1:21 pm
All three of those Magnatec oils contain additives which are likely to cause a wet clutch to slip.
If you want cheap but good oil that conforms to JASO specs then I'd recommend this https://www.opieoils.co.uk/p-73843-shell-advance-ax7-10w-40-four-stroke-engine-oil.aspx - currently £19.99 for 4 litres or £36.95 for 8 litres.
Post by wornsprokets on Fri 11 Jan 2019, 10:13 am
Ive halfords 10/40 semi  car oil(green halfords brand) for years in both cb&cbs never had any problems... With the  clutch
Post by jchesshyre on Fri 11 Jan 2019, 11:43 am
@wornsprokets wrote:Ive halfords 10/40 semi  car oil(green halfords brand) for years in both cb&cbs never had any problems... With the  clutch
This may well not contain friction modifiers that cause wet clutch slip - not all car oils do, but by the sound of it the Castrol Magnatec does - '...has Intelligent Molecules, which cling to your engine to form an extra layer that protects during warm-up and beyond. The Intelligent Molecules cleverly bond to metal surfaces making engine parts more resistant to wear and gives you super performance under extreme cold start up conditions.'
Post by Beresford on Fri 11 Jan 2019, 1:07 pm
Has ANYBODY on here ever had clutch problems due to using car oil ? It would be interesting to know.
hh_12345
hh_12345
Laser Shark
Laser Shark
Post by hh_12345 on Fri 11 Jan 2019, 1:17 pm
I guess those molecules are intelligent enough not to bond to clutch plates. drunken
GollyGosh
GollyGosh
Post by GollyGosh on Fri 11 Jan 2019, 2:13 pm
@jchesshyre wrote:All three of those Magnatec oils contain additives which are likely to cause a wet clutch to slip.
Best buy from opieoils is 16ltr (4x4ltr) £72.95 and qualifies for free postage.
Note: 1x4ltr + £4.99 postage = £24.98
Currently on eBay 1x4ltr £21.50 with Free delivery
Crash- Elmit
Crash- Elmit
Post by Crash- Elmit on Fri 11 Jan 2019, 3:03 pm
I cant remember what oil I had put in not long after buying the CB, but clutch started slipping on the A47 towards Peterborough during a trip to Skeggy. I thought the plates were worn out so bought a new set, including stronger springs from EBC, and stipped clutch to fit them but there was nothing wrong with original plates and they were also near top limit in thickness. The only issue I could see was some slight bluing to the metal plates.
(It's not good when engine speed starts to climb rapidly but road speed stays the same)
Post by Beresford on Sat 12 Jan 2019, 12:24 am
What did you do to solve the problem ? Change everything or just the oil ?
Crash- Elmit
Crash- Elmit
Post by Crash- Elmit on Sat 12 Jan 2019, 2:31 am
@Beresford wrote:What did you do to solve the problem ? Change everything or just the oil ?
I flushed the system, put a new oil filter on and filled it with Halfords 10w40 and put the old plates back on.
The clutch has been fine since
Post by Beresford on Sat 12 Jan 2019, 9:52 am
@Crash- Elmit wrote:and filled it with Halfords 10w40
Car stuff ?
Crash- Elmit
Crash- Elmit
Post by Crash- Elmit on Sat 12 Jan 2019, 1:03 pm
Car stuff ?
No, it was 4 stroke motorcycle oil
    Current date/time is Tue 17 Sep 2019, 7:43 am
