Coolant top up through coolant reserve tank?
fgclark123
fgclark123
Post by fgclark123 on Tue 20 Nov 2018, 1:10 pm
Hi there, can I top up the coolant through the reserve tank?
I used distilled water this summer, whilst in a hot country, so now back in blighty gotta get the lower freezing point coolant in.
I know how to drain, just need to top up. Don't want to take off the petrol tank if I can avoid it.
Re: Coolant top up through coolant reserve tank?
Post by Jameshambleton on Tue 20 Nov 2018, 5:15 pm
Unless there is 0 air in the system then your coolant will not get siphoned through into the main system
Post by eternally_troubled on Tue 20 Nov 2018, 8:07 pm
You need to take the tank off, no other way.
The thing under the airbox is only a reserviour/overflow - you can put as much antifreeze in there as you want but only a little bit (at most) will ever get into the system.
fgclark123
fgclark123
Post by fgclark123 on Sun 25 Nov 2018, 9:28 pm
damn, ok thanks. little bit of work then. cheers.
    Current date/time is Mon 18 Mar 2019, 11:57 pm
