throttle "travel" - too much twist?
throttle "travel" - too much twist?  Empty throttle "travel" - too much twist?
Post by trevor machine on Thu 27 Sep 2018, 4:51 pm
Do you ever get this - I sometimes feel that the bike's throttle has too much twist to it. I'm not a nutter but I ride flat a fair bit on it, i.e. on the stop, wringing revs and power from the bike. But I almost have to give two twists, as it were - otherwise my wrist is at 90 degrees. And this pisses me off a bit. I wish there was a bit less wind - say, 10-15%. I know that on the MT07 people have similar experiences and have swapped the throttle tube for a R6, so there isn't as much twist. This is generally much preferred by those who've tried the mod.
throttle "travel" - too much twist?  Empty Re: throttle "travel" - too much twist?
Post by sullivj on Thu 27 Sep 2018, 7:03 pm
I have the same problem, and have to 'double grab' to wind it on.
I remember Jerryfudd did some kind of throttle upgrade to fix this.
Maybe ask the same question of the racing boys on the Thundersport FB group. They must have a solution.
Post by ceejay on Thu 27 Sep 2018, 7:13 pm
Somewhere on this site someone (probably Jerryfudd) listed the dimensions for a piece of material to go under the throttle cable at the bars... I've had these dimensions noted down for about 3 years without actually doing anything about it : )
throttle cable mod (31mm inside diameter 2.1mm depth  7mm wide)
hh_12345
hh_12345
Laser Shark
Laser Shark
Post by hh_12345 on Fri 28 Sep 2018, 8:26 am
It feels the same on mine, but I got used to it (as with many other things on the bike Very Happy).
There are two topics on the throttle tube action:
http://www.cb500club.net/t3767-throttle-tube-replacement
http://www.cb500club.net/t4020-quick-action-throttle-for-free
Post by trevor machine on Fri 28 Sep 2018, 8:38 pm
Hey nice one guys. I'll have a dekko at that. Cheers! ; - )
Post by eternally_troubled on Wed 24 Oct 2018, 10:53 pm
Also made much worse if you have *slightly* slipping heated grips... Wink
    Current date/time is Tue 15 Oct 2019, 2:40 pm
