Brake disc out of true
theblackorder
theblackorder
Brake disc out of true Empty Brake disc out of true
Post by theblackorder on Mon 20 Aug 2018, 9:48 am
Is it possible to straighten brake disc and has anyone done that. I'm getting mild front end chatter during braking. Also if I am to replace the front disc can you suggest aftermarket one or the oem is best.
motofan
motofan
Brake disc out of true Empty Re: Brake disc out of true
Post by motofan on Mon 20 Aug 2018, 7:33 pm
Place a pointer near to the disc. Spin the front wheel and check that the gap changes, if it does the disc is warped, best to change it I've never heard of anyone straightening one, it might be dangerous to do it even if it is possible.
If the disc is not warped check your steering head bearings, if they're loose they'll judder under braking.
    Current date/time is Mon 23 Sep 2019, 2:56 pm
