fitting a s model fairing
hh_12345
Post by hh_12345 on Fri 17 Aug 2018, 4:06 pm
I was wondering what to do to the cb in near future and thought that trying to install a fairing would be a nice opportunity to waste time and money. It would be a stylish addition to the bike too.
Is it possible to fit the s model fairing to non s model frame - is there a certain point at the frame head tube where the cowl bracket is attached that could be missing on the standard frame? Also are the s model clocks a straight fit or they would require some modification of the wiring.
Re: fitting a s model fairing
Post by Beresford on Fri 17 Aug 2018, 6:57 pm
There are quite a few differences including the top yoke and handlebar mounts. I don't know whether that is because of clearance issues between the two models. The 'S' clocks also have a tubular mounting frame, also supporting the fairing.
Someone may correct me, but I believe that the headstock/trail angle differs also.
hh_12345
Post by hh_12345 on Fri 17 Aug 2018, 7:58 pm
Thanks, Beresford, I'll look for some info for the yoke and trail angle.
Apart from the clocks/fairing  frame, there is a bracket for the head light and a pair of brackets for attaching the fairing to the tank.
Post by Jameshambleton on Fri 17 Aug 2018, 8:30 pm
Yokes are different, the loom is different so you'd have to change the entire loom just to fit the S clocks ,
hh_12345
Post by hh_12345 on Fri 17 Aug 2018, 9:20 pm
Thanks, James. That would be too much.
I'd better put a puig screen for a difference or content myself with the occasional change of side covers color.
Post by ANDYC on Sat 18 Aug 2018, 7:54 am
The frame is indeed different for the S model.
As well as the clocks, yokes, loom etc.
    Current date/time is Wed 16 Jan 2019, 10:15 pm
