Spark plug heat range
theblackorder
theblackorder
Spark plug heat range Empty Spark plug heat range
Post by theblackorder on Wed 15 Aug 2018, 2:41 pm
I wonder if I should go with NGK CR8EH-9 (standard) or CR9EH-9 as Haynes suggests for "extended high speed riding". Also I plan to change the stock air filter for high flow one, which should rise the temperature in the combustion chamber. Any ideas?
Spark plug heat range Empty Re: Spark plug heat range
Post by eternally_troubled on Wed 15 Aug 2018, 7:59 pm
I've always used the standard ones and never had a problem, both with the normal paper filter and a K&N.
By all means try the other heat range - it will be interesting to see what happens Smile
burudis
burudis
Post by burudis on Wed 15 Aug 2018, 9:14 pm
high flow sprint filter in poliester.
dont need washing.only with air pressure
Post by Jameshambleton on Wed 15 Aug 2018, 10:20 pm
^ no idea what that means
I use cr9eh9's
    Current date/time is Tue 17 Sep 2019, 7:13 am
