Front sprocket bolt
The Hurricane
The Hurricane
Front sprocket bolt Empty Front sprocket bolt
Post by The Hurricane on Wed 01 Aug 2018, 12:59 am
Which way does the front sprocket bolt undo. I have put a piece of wood in the rear wheel to lock it up and have tried undoing the bolt both directions and it won't budge but I didn't want to force it if I am going the wrong way. Any ideas please.
Front sprocket bolt Empty Re: Front sprocket bolt
Post by Jameshambleton on Wed 01 Aug 2018, 5:03 am
I'm 99% sure it's just a standard thread. Mine's alway a pain to get off as when the sprocket is turning anticlockwise it's effectively always tightening the bolt up
skyerae
skyerae
Post by skyerae on Wed 01 Aug 2018, 6:11 am
It is as James says, I put the engine into gear (first) to stop the bike moving. I use a breaker bar that is just over 3 foot to get it to crack loose. If you only torque the nut up to 55Nm (the Hayes manual information) it will not come loose but will come off with a using breaker bar. Done this a few times and not had ant issues.
Post by Jameshambleton on Wed 01 Aug 2018, 12:43 pm
I have to chock my rear wheel every time, I tried it in gear and with someone standing on the back brake - I moved the bike forwards so just use wood through the rear wheel
freeride
freeride
Laser Shark
Laser Shark
Post by freeride on Wed 01 Aug 2018, 8:46 pm
Agreed you need a long tube but use a socket with a bar on it rather than a rachet handle.
Post by Beresford on Wed 01 Aug 2018, 9:57 pm
Or a ring spanner and whack it with a rubber mallet.
The Hurricane
The Hurricane
Post by The Hurricane on Wed 01 Aug 2018, 11:09 pm
Sorry from the replies I am still not sure which way the bolt comes undone.
Post by Jameshambleton on Thu 02 Aug 2018, 7:01 am
@The Hurricane wrote:Sorry from the replies I am still not sure which way the bolt comes undone.
Lefty loosey in this case
The Hurricane
The Hurricane
Post by The Hurricane on Thu 02 Aug 2018, 8:39 am
Cheers everybody for your replies. Watched a video on Youtube of a fella undoing his on his CB500 and undone mine this morning and I think the weetabix helped.
    Current date/time is Fri 24 May 2019, 11:58 pm
