Carb balance problem
wrighty
wrighty
Carb balance problem Empty Carb balance problem
Post by wrighty on Fri 20 Jul 2018, 9:10 pm
A question for the technically minded. Trying to balance carbs using Carbtune vacuum thingy. Using the balance screw between carbs i get a good balance at tickover but when i give some revs right side flies up and left side doesn't do very much. Am i looking at a blocked main jet? Is it cos idle jets are clear but one main jet is blocked. Have i got to take the bloody carbs off again. What other possibilities are there? As no fuel is flowing without the vacuum pipe attached is one side running out of fuel before the other? Grateful for any thoughts.
Sorry guys i guess this should be in Workshop!
Carb balance problem Empty Re: Carb balance problem
Post by ANDYC on Fri 20 Jul 2018, 10:04 pm
It could be worth checking the diaphragms to make sure that one isn't leaking or torn. Probably the right side. It could be that debris from the secondary filter (they fall apart and end up in the vacuum chamber ) is preventing the slide from opening properly.
If you're getting a good tickover then as the idle jets are much smaller than the mains I doubt that it would be blocked.
Also check for air leaks around the inlet and airbox rubbers.
wrighty
wrighty
Post by wrighty on Sat 21 Jul 2018, 8:15 am
Thanks for that Andy, a weekend of investigation ahead.
wrighty
wrighty
Post by wrighty on Mon 23 Jul 2018, 3:21 pm
@ANDYC wrote:It could be worth checking the diaphragms to make sure that one isn't leaking or torn. Probably the right side. It could be that debris from the secondary filter (they fall apart and end up in the vacuum chamber ) is preventing the slide from opening properly.
Non of that necessary Andy, I thought before getting too involved I should check that we (my mate whos carbtune it is and I) were doing everything correctly. Quick read of instructions and it seems the 2 vacuum hoses have a restrictor at one end an this should be towards the engine in both (BOTH) cases. Lo an behold with that sorted good readings all round. This final running with blue coolant has at least shown me where the one small leak is, so that is next job. Cheers
Post by ANDYC on Mon 23 Jul 2018, 9:34 pm
Glad it turned out to be nothing Very Happy
GollyGosh
GollyGosh
Post by GollyGosh on Tue 24 Jul 2018, 12:14 pm
Many problems are solved by RTFM study
Smile
wrighty
wrighty
Post by wrighty on Tue 24 Jul 2018, 3:47 pm
Yes indeed. Its a male thing isnt it. Just do it an when it goes wrong, as you say, RTFM! Its my friends carbtune and i assumed he knew what was what. He's ex RAF, I should have known! The good thing is engine running and sounding good. Will fix this small coolant leak from the coolant inlet manifold on front of block tomorrow and start thinking about front end mods.
GollyGosh
GollyGosh
Post by GollyGosh on Wed 25 Jul 2018, 12:32 pm
Normally RAF are the more intelligent of the armed forces.
Soldiers go into battle and leave the officers behind, sailors go into battle with the officers whilst airmen stay behind and send the officers into battle.
Smile
wrighty
wrighty
Post by wrighty on Wed 25 Jul 2018, 6:51 pm
Yes but us pongo's have more fun. There's nothing like digging a trench and living with the worms for a week eating compo field rations! Sleep what sleep? Ahh I do miss it!
Post by Jameshambleton on Wed 25 Jul 2018, 9:01 pm
Just corrected your first sentence for you @GollyGosh
GollyGosh
GollyGosh
Post by GollyGosh on Thu 26 Jul 2018, 12:17 am
@Jameshambleton wrote:Just corrected your first sentence for you @GollyGosh
To be fair there's always an exception to prove the rule.  Rock apes ? Laughing
Joking apart, I've not met a dumb one (he wrote fearing for his life)
wrighty
wrighty
Post by wrighty on Thu 26 Jul 2018, 4:26 pm
I'm outnumbered. I give in.
Post by Jameshambleton on Thu 26 Jul 2018, 8:54 pm
@wrighty wrote:I'm outnumbered. I give in.
You do make good cuppa's though =D
    Current date/time is Tue 23 Jul 2019, 6:21 am
