Type of grease for steerer bearing
robyn131
robyn131
Type of grease for steerer bearing Empty Type of grease for steerer bearing
Post by robyn131 on Sat 14 Jul 2018, 6:30 pm
Hi, I have a replacement bearing kit to do the job but it doesn't say what grease to use. Anyone know?
Not done this job before, fairly confident in what I'm doIng, but any useful tips would be appreciated.
Type of grease for steerer bearing Empty Re: Type of grease for steerer bearing
Post by eternally_troubled on Sun 15 Jul 2018, 11:59 pm
Almost any grease.  Maybe not pig fat or goose grease, unless you don't have anything else :)
More seriously, a multipurpose grease like the one sold by Halfords here:
https://www.halfords.com/motoring/engine-oils-fluids/grease/comma-multi-purpose-grease-500g
will be fine for the head bearing.  There isn't much very 'special' about, hence the 'multi purpose'.
Essentially if you go into any place that sells car parts/supplies and say 'I want your cheapest multi purpose grease' you will get something that will be fine.
Also, getting the bearing races out of the head-tube is somewhat of a battle...
robyn131
robyn131
Post by robyn131 on Sun 22 Jul 2018, 3:12 pm
Thanks for the reply. I have a tub of Lithium 2 grease so will use that.
I've found a few threads on here with helpful tips on replacing the bearings and how difficult the races can be, at least i'm going in prepared!
Post by eternally_troubled on Sun 22 Jul 2018, 8:03 pm
Yes, it is 'do-able', it's just that your first mechanism for removing the bearing races might fail and you might need to be ready with some alternatives. Probably for the best you have read the other threads Wink
robyn131
robyn131
Post by robyn131 on Fri 27 Jul 2018, 4:55 pm
Job done! Defiantly recommend watching the youtube 'how to' videos for anyone going to attempt this job. I used an 8mm blunt wood chisel to begin with, then a 20mm masonry chisel for the final stages to remove the races, took about 20 mins per race.
burudis
burudis
Post by burudis on Sat 28 Jul 2018, 10:02 pm
i use motorex long time grease.
Or one disulphure molibden grease
    Current date/time is Sat 25 May 2019, 12:10 am
