Hot weather whirring or droning noise?
fgclark123
fgclark123
Hot weather whirring or droning noise? Empty Hot weather whirring or droning noise?
Post by fgclark123 on Sat 07 Jul 2018, 3:10 pm
Hi there, I've noticed a strange whirring/droning noise underneath the main engine sound. It seems to exert a very slight braking effect also. About 2 drones per second.
I was wondering if it's the water pump, given the heat. Also, I've been running pure distilled water rather than pink coolant, as I'm in spain and don't know if the correct coolant is available. Perhaps I've gone and knackered something?
Cheers chaps, happy riding
fgclark123
fgclark123
Hot weather whirring or droning noise? Empty Re: Hot weather whirring or droning noise?
Post by fgclark123 on Sat 07 Jul 2018, 3:32 pm
I should add, the whirr happens when I'm coasting down hill engine off. It gets faster the faster I go. Honestly no bloody idea! Thanks a lot
fgclark123
fgclark123
Post by fgclark123 on Sat 07 Jul 2018, 4:23 pm
... also there is no whirr when I sit stationary and rev... so ok it must be some system I am ignorant of... Thanks guys.
Post by eternally_troubled on Sat 07 Jul 2018, 5:53 pm
@fgclark123 wrote:I should add,  the whirr happens when I'm coasting down hill engine off.  It gets faster the faster I go.  Honestly no bloody idea! Thanks a lot
It's your chain/sprockets, or, at least, something in that area. Don't know what exactly, but, when you are coasting downhill, the drive is 'in the wrong direction' for the wear on the chain/sprockets (i.e. rear wheel is leading/pushing the engine, rather than the more usual situation where the engine is pulling the rear wheel).
I'm not entirely surprised it makes a slight rattling/whir/noise. If it is only when coasting downhill the I wouldn't worry.
The only significant problem that distilled water will cause is your coolant boiling! Distilled water boils at 100 degress, whereas all/any suitable coolant mix for the CB500 boils at a higher figure (108 or so).
The CB500 doesn't require any particularly special type of coolant AFAIK; as long as it is suitable for aluminium engines and suitably diluted it should be fine. I've quite happily used the blue stuff from Halfords without a problem.
fgclark123
fgclark123
Post by fgclark123 on Mon 09 Jul 2018, 12:00 pm
Yes you're right - it was the bearings, absolute mess. I carro ed a pillion for a couple of days, could've been that.currently on a spanish workshop putting it right under breakdown insurance. Fingers crossed should be back on the road soon.
Cheers though thanks very much. Live and learn...
Post by eternally_troubled on Thu 12 Jul 2018, 5:41 pm
Which bearing was it? I've been through a few sprocket carrier bearings; seems to eat them at a fair rate! Luckily they are not expensive or difficult to fit.
fgclark123
fgclark123
Post by fgclark123 on Fri 13 Jul 2018, 9:09 am
Hi there, unsure of the name, but here's a pic.Hot weather whirring or droning noise? 11210
Do you have a seller you'd recommend? I'd like to have a few on hand for touring situations. thanks
GollyGosh
GollyGosh
Post by GollyGosh on Fri 13 Jul 2018, 3:06 pm
Looks like a previous owner wanted to save a couple of pence.  Should be sealed bearings to keep the grease in and the dirt out also they last a lot longer.
James has a post with original Koyo part numbers here Bearings and Seals
Once you've found the bearing number go HERE for current Koyo number and alternative makers, NSK and SKF.
As for a seller, to quote James from another post "You want NSK bearings, have a look at simplybearings.co.uk"
fgclark123
fgclark123
Post by fgclark123 on Fri 13 Jul 2018, 9:24 pm
great thanks. I think the stock replacement is already whirring to itself, may need these soon. cheers
Post by eternally_troubled on Sat 14 Jul 2018, 11:35 am
That's a wheel bearing; you might as well replace the one on the other side as well.
If you pull the sprocket carrier out of the rear wheel/cush-drive then the sprocket carrier bearing is the one that is in the sprocket carrier.
burudis
burudis
Post by burudis on Sat 14 Jul 2018, 6:01 pm
aditives in coolant liquid help pump etc.
suerte cuñado.
    Current date/time is Sat 25 May 2019, 1:07 am
