Fork seals
ChrisTL
ChrisTL
Fork seals Empty Fork seals
Post by ChrisTL on Fri 29 Jun 2018, 11:06 pm
Any tips on how to release a fork seal on a 1995 CB500. Just failed big time using the pulling the stantion so that the lower bush hits against upper bush and seal method. The seal didn't move after a lot of effort and it kept jamming - is one bush catching inside the other? Heat didn't help. Are these known to be tight - it looks so easy on YouTube.
Crash- Elmit
Crash- Elmit
Fork seals Empty Re: Fork seals
Post by Crash- Elmit on Sat 30 Jun 2018, 1:08 am
just gently keep heating the area around the seal and it will come out
Post by Jameshambleton on Sat 30 Jun 2018, 8:41 am
Have you popped the dust seal out and removed the circlip that holds the seal in place?
Post by eternally_troubled on Wed 04 Jul 2018, 10:53 pm
It always looks easy on youtube Smile Assuming you have removed the dust seal and the circlip, then applying the heat and being persistent is the way forward.
There are other methods (like filling the fork with water, compressing it and using water pressure to pop it out) but they aren't as easy.
    Current date/time is Sat 25 May 2019, 12:38 am
