1997 CB 500 fork oil amount
hawksquawks
hawksquawks
1997 CB 500 fork oil amount  Empty 1997 CB 500 fork oil amount
Post by hawksquawks on Sun 24 Jun 2018, 12:18 am
Hello recently needed to replace my CB 500 fork seals Id like to know how much oil in mm I need to put in from empty 1997 model.  or at least reg anyway.
turista
turista
1997 CB 500 fork oil amount  Empty Re: 1997 CB 500 fork oil amount
Post by turista on Sun 24 Jun 2018, 3:35 am
Compress the fork and leave 140mm free to the top, the rest with oil, 10w or 15w. Font know the oil volume, just the space for air.
wrighty
wrighty
Three's a Charm
Three's a Charm
Post by wrighty on Sun 24 Jun 2018, 7:29 am
Haynes give amount as 309 to 320cc depending on model. 309 for 500t, 313 for 500v and 320cc for all others. Top of oil to top of fork tube (compressed) is 165mm for500t, 160mm for 500v and 150mm for all others.
Post by eternally_troubled on Sun 24 Jun 2018, 12:05 pm
@wrighty wrote:Haynes give amount as 309 to 320cc depending on model.
The good thing is that if you put (approx) 315cc (or 315ml if you prefer) that will be fine (or at least pretty close) for all of them. I'm not sure that 5ml of fork oil makes a big difference either way... I think it's more important to make sure you change it regularly!
    Current date/time is Mon 27 May 2019, 6:26 am
