Mystery hose
fgclark123
fgclark123
Mystery hose
Post by fgclark123 on Sun 03 Jun 2018, 12:42 pm
Putting the machine back together after replacing water pump seals. Any idea if this pipe should be free like this or am I missing something?!? thanks
Re: Mystery hose
Post by Jameshambleton on Sun 03 Jun 2018, 1:44 pm
Goes on the back side of the fuel tap. Pull it off the brass connector where it currently is. Connect the other end to the back side of the fuel tap (you'll need to lift the tank to access it) Then slide it back onto the current location on the bass connector.
fgclark123
fgclark123
Re: Mystery hose
Post by fgclark123 on Sun 03 Jun 2018, 2:12 pm
great man thanks
Re: Mystery hose
Post by teamster1975 on Sun 03 Jun 2018, 5:35 pm
@fgclark123 wrote:great man thanks
You won't get far without it connected either, it's the vacuum hose for the fuel tap. Check there are no splits in the end as the rubber does go hard with age, you can get away with trimming off the end.
Re: Mystery hose
    Current date/time is Wed 20 Feb 2019, 5:53 pm
