Steering damper
fgclark123
fgclark123
Steering damper Empty Steering damper
Post by fgclark123 on Mon 28 May 2018, 10:03 pm
Not sure if the 500 requires one, but thought I'd see what the approach is anyway. Anyone bothered installing one? Does it make a big difference? Thanks
Steering damper Empty Re: Steering damper
Post by Jameshambleton on Tue 29 May 2018, 12:08 pm
Unless you're running super sticky tyres and cracking the throttle open (not rolling on) making the front come up while exiting corners you don't need a steering damper.
fgclark123
fgclark123
Post by fgclark123 on Tue 29 May 2018, 7:56 pm
appreciated thanks.
Post by ANDYC on Wed 30 May 2018, 8:22 am
The steering angle on the cb500 is too laid back to need a steering damper.
Mine have always been rock steady.
fgclark123
fgclark123
Post by fgclark123 on Wed 30 May 2018, 12:44 pm
you mean the angle between the forks and the road? cheers.
I sometimes notice a very lght wobble when cornering and at a certain low-ish rev count...
Post by ANDYC on Wed 30 May 2018, 1:45 pm
That's more likely to be down to tyres or suspension, possibly steering head bearings.
A steering damper would probably make it worse.
fgclark123
fgclark123
Post by fgclark123 on Wed 30 May 2018, 2:12 pm
ok. to be precise, it's noticable when I decelerate, say from 40 to 20, without using the breaks or changing gear, so engine braking. if I rest my hands lightly on the bars, they start to wobble when the revs come down around 3.5k rpm... sounds familiar at all? thansk
Post by Jameshambleton on Wed 30 May 2018, 2:37 pm
Front tyre wear, common on bridgestones if your pressures haven't been maintained or at the proper pressure.
    Current date/time is Sun 22 Sep 2019, 2:14 pm
