Rear tyre change
fgclark123
fgclark123
Rear tyre change Empty Rear tyre change
Post by fgclark123 on Fri 25 May 2018, 3:01 pm
I'm due a rear tyre change. What do you think, is this something you could tackle at home? What kind of tools/expertise are needed? I suspect it's beyond casual maintenance tasks, but any thoughts? cheers
Rear tyre change Empty Re: Rear tyre change
Post by Jameshambleton on Fri 25 May 2018, 4:37 pm
Massive tyre irons are needed and it's a massive farthing about trying to break the bead, for the cost of £12 I get them fitted and balanced. Remember that tyres are classed as commercial waste so you'll have to pay to get rid of the old one.
It took two people jumping on a spade (simultaneously) to break the bead on one of his wheels and we were at it for over an hour.
Post by eternally_troubled on Sat 26 May 2018, 5:47 pm
Yes you can do it at home. It's much easier to use a second class lever to break the bead - i.e. a bit of timber with the end trapped under something heavy (like a car) and a little bit of wood to press down the bead - you press down on the end of the lever and hey presto.
The use of the tyre irons/levers and manipulation of the tyre is a skill - I haven't cracked it (i.e. I still sweat buckets and swear at the tyres!) but it isn't just about brute force (although some is quite handy).
If you want to buy tyre changing stand and one of those special levers with a plastic end you can do it quite easily (a little more expensive though).
    Current date/time is Sat 20 Jul 2019, 10:50 am
