Rear wheel hub assembly moving - worn rubber internal parts?
fgclark123
fgclark123
Post by fgclark123 on Fri 25 May 2018, 11:40 am
hi there,
Just need to check on what's wrong with my rear wheel. The rear brake disc and hub assembly has movement independent of whether the chain is pulling it around. A few mms back and forth.
I went on a maintenance course and was told a certain rubber internal part is worn - I can't remember the name. Apparently it's a fairly easy fix. Daft question ut does anyone know what I'm talking aout?
thanks
fgclark123
fgclark123
Re: Rear wheel hub assembly moving - worn rubber internal parts?
Post by fgclark123 on Fri 25 May 2018, 11:42 am
Guess it could be part 1 on this -" damper set wheel" but I think it had a different name...
https://www.bike-parts-honda.com/pieces-honda-detail-1216-13MY52I1-CB5002-2002-F__1300-CB+500.html
anyway thanks
Post by teamster1975 on Fri 25 May 2018, 1:17 pm
It's the cush drive rubbers, and yes they are no 1 on the link you posted. It's possible one of the rubbers had dropped out when it was apart at a previous time, they can't really go anywhere when it's assembled.
Here's a link with a far more sensible price:
https://www.motorcycleproducts.co.uk/sprocket-rubbers-honda-cb500-twin-1998-99-p-76249.html?gclid=Cj0KCQjw6J7YBRC4ARIsAJMXXserAj3bQxpHPaypJJ8kOCc_5uZA9LSBa1-HNrl9KSlm5Iw7d3-H2QgaAt4yEALw_wcB
Edit: Even better link on Ebay for £10!
Post by Jameshambleton on Fri 25 May 2018, 2:27 pm
There is always a few degrees of movement between the sprocket and the wheel.
Usually the rubber connector that goes over the lugs in the wheel perishes. I've just ordered a set for mine a few days ago as I've lost some since I've changed the wheels over.
I ordered this https://www.ebay.co.uk/itm/141581000512 should be here in the next few days
fgclark123
fgclark123
Post by fgclark123 on Fri 25 May 2018, 2:58 pm
cool, thanks a lot. is this an area where a serious flaw can emerge if not sorted?  I mean, presumably either my wheel or sprocket is taking some beating with every throttle change at the moment?
Post by Jameshambleton on Fri 25 May 2018, 4:30 pm
Given all the rubbers are in there you've got nothing to worry about, I was popping wheelies with having a good few rubbers missing/perished. You won't be doing any damage.
shropshirewildman
shropshirewildman
Post by shropshirewildman on Fri 25 May 2018, 10:01 pm
On the way back from spain last year I stopped in the Pyrenees to get a rear tyre changed .when the guy took the wheel out, the sprocket carrier bearing just fell apart. So I would guess that's worth checking while you're at it.
Post by eternally_troubled on Sat 26 May 2018, 5:48 pm
While you are there, check the wheel bearings and sprocket carrier bearing...
    Current date/time is Wed 20 Feb 2019, 5:11 pm
