Water pump seal replacement
fgclark123
fgclark123
Post by fgclark123 on Fri 25 May 2018, 00:17
Hi people,
I've finally traced the source of a leak , I think the only leak on the machine, so that's great.
I had a garage look it over, apparently between the water pump and the engine is a seal or a gasket. I don't even know what a gasket is, so that's bloody great.
*gasket* - a mechanical seal which fills the space between two or more mating surfaces, generally to prevent leakage from or into the joined objects while under compression
ok well... so I know that now. What is the part I'm looking for? Is it sold alone? Do you know where I mean, between the engine and the pump?
jonny10
jonny10
Re: Water pump seal replacement
Post by jonny10 on Fri 25 May 2018, 01:06
Have a look at the stickied microfiche in Workshop section
Sounds like item 5 on the link -
https://www.bike-parts-honda.com/pieces-honda-detail-1216-13MY52I1-CB5002-2002-E__1000-CB+500.html
Post by Jameshambleton on Fri 25 May 2018, 10:30
99% sure it's just a standard o-ring - just checked Jonny's link and it's spot on
fgclark123
fgclark123
Post by fgclark123 on Fri 25 May 2018, 12:21
I'll replace both 5 and 9 - the o ring an the gasket. cheers guys, fingers crossed.
fgclark123
fgclark123
Post by fgclark123 on Fri 01 Jun 2018, 22:23
Hi there, I've started this job - to get at the O-ring seals and replace them.
First thing in the Haines manual is, drain the coolant. That requires removing the fuel tank.
All of a sudden the job takes on monstrous proportions! I should've seen it coming.
So, is it possible to switch out these seals in any way that doesn't involve fuel tank removal? I thought it might be a simpler job than this.
Post by ceejay on Fri 01 Jun 2018, 22:37
I don't have my Haynes handy but yeah definitely a good idea to read through the entire procedure before embarking on this, could be a few other 'remove this, remove that' for water pump seal replacement (engine oil?)
Fortunately tank removal is relatively easy and not as messy like you might imagine. It will need to be removed to get to the coolant filler cap which is under it. Coolant will need to be drained before you get to the water pump then refilled using the cap under the tank once you've put the new seal in.
First bike I ever owned had a leaking water pump seal.. I remember it seeming like such a daunting job at the time, so many things had to be done to get to it and I didn't understand why! However once you've done these things a few times and seen the inner workings it all seems simple and makes much more sense...
fgclark123
fgclark123
Post by fgclark123 on Sat 02 Jun 2018, 11:03
Ok thanks, well, here we go...
Here's the manual by the way, pdfs downloadable.
https://app.box.com/s/6fcd52ade07b644ddbac
fgclark123
fgclark123
Post by fgclark123 on Sat 02 Jun 2018, 16:36
(fuel tank off... man the lessons you learn...)
fgclark123
fgclark123
Post by fgclark123 on Sat 02 Jun 2018, 18:09
Can anyone advice on a coolant brand? I see I need 50% "corrosion inhibited ethylene glycol antifreeze" per the manual, 50% distilled water. Any brand will do or...?
When draining the current coolant, I seem to have sullied it with a little oil from the frame. Thought I might as well replace.
fgclark123
fgclark123
Post by fgclark123 on Sat 02 Jun 2018, 20:14
ps. found posts on coolant type, thanks
Post by eternally_troubled on Sat 02 Jun 2018, 20:30
That's 'normal' antifreeze then Smile
For the record I used the blue stuff from Halfords without a problem.
    Current date/time is Wed 20 Feb 2019, 18:24
