OIL PRESSURE
OIL PRESSURE Empty OIL PRESSURE
Post by ANDYC on Sun 13 May 2018, 1:55 pm
I would like to pose a question to anyone out there that has a genuine Honda workshop manual for our steed of choice.
The Haynes manual gives the oil pressure as 34psi with the oil at 80 degrees, could this be a misprint?
This seems very low to me as every other Honda that I have worked with seems to be around the 70-80psi mark.
It's not been noticable when the oil warning light is either on or off, but I would like to be fitting a guage to my track bike so knowing the range would be helpful. scratch
As always thanks for your help in advance.
OIL PRESSURE Empty Re: OIL PRESSURE
Post by Jameshambleton on Sun 13 May 2018, 5:51 pm
Just had a look in my Honda shop manuals and nothing in there about the pressure scratch
Post by ANDYC on Sun 13 May 2018, 6:16 pm
That's curious James.
GGG267
GGG267
Post by GGG267 on Fri 23 Aug 2019, 9:41 pm
Haynes. Manual page1.2 34 psi @ 2000 rpm
GGG267
GGG267
Post by GGG267 on Fri 23 Aug 2019, 9:46 pm
Any thoughts on oil light staying on and engine stopping, what do I need to check etc
Post by ANDYC on Sun 25 Aug 2019, 12:18 pm
@GGG267 wrote:Haynes. Manual page1.2 34 psi @ 2000 rpm
Yes, that's where I got my info from.
Just hoped someone could confirm it from the genuine manual.
Post by ANDYC on Sun 25 Aug 2019, 12:30 pm
@GGG267 wrote:Any thoughts on oil light staying on and engine stopping, what do I need to check etc
Take off the sump and check the oil pickup screen is clear.
Although if the engine is stopping then the damage will be done already.
How exactly is the engine stopping?
Does it run until it gets hot? Does it idle at the correct speed?
If the idle speed is too low then the light will stay on and the engine will cut out too. Try turning up the idle speed and see if the light will go out.
What's the oil like in there?
Just a few things to consider before my first suggestion, past experiences have taught me that careless use of silicon or thread locking compound end up blocking the pickup screen.
GGG267
GGG267
Post by GGG267 on Sun 25 Aug 2019, 1:52 pm
It stops when hot , the s for a bit and then stop again
GGG267
GGG267
Post by GGG267 on Sun 25 Aug 2019, 1:53 pm
Possible damage done
GGG267
GGG267
Post by GGG267 on Sun 25 Aug 2019, 1:55 pm
The low oil pressure is only an indication so I assume the engine is overheating with no oil getting to all the moving parts, the water temperature gauge stats normal
Post by ANDYC on Sun 25 Aug 2019, 2:27 pm
I would say that a complete stripdown is the best way to check the damage and cause I'm afraid.
burudis
burudis
OIL PRESSURE Empty oo
Post by burudis on Mon 26 Aug 2019, 5:22 pm
no oil pressure is catastrophic then otherwise the pressure is correct.
Trocoidal pump via clutch chain only has two readings: OK ò new motorcycle .....
burudis
burudis
OIL PRESSURE Empty oi
Post by burudis on Wed 28 Aug 2019, 1:05 pm
French workshop manual of ETAI publisher gives a pressure of 2,4kg to 2,000 rev.
also the honda factoy manual gives, on page 1-5:
235 kPa (2.4 kglcm'i in
2,000 min- '(tr / mn) (80 ° C)
Post by ANDYC on Wed 28 Aug 2019, 1:09 pm
Thank you,  that confirmed that the 34 psi @ 2000rpm is correct then.
    Current date/time is Mon 23 Sep 2019, 1:58 pm
