crack
cbcombo
cbcombo
crack
Post by cbcombo on Thu 10 May 2018, 9:52 am
Noticed this yesterday when de-cruding project CB as anyone had similar?
Re: crack
Post by Jameshambleton on Thu 10 May 2018, 9:57 am
Common failure point on the bike, though it usually only cracks when someone attempts to remove the seized on bolt that runs though the casing
cbcombo
cbcombo
Re: crack
Post by cbcombo on Thu 10 May 2018, 10:24 am
Thought that was the case, not too concerned though.
Re: crack
Post by eternally_troubled on Sun 13 May 2018, 10:07 am
That's not a crack, it's a lubrication point Wink It will help if you chuck some plusgas (or other penetrating oil in there) before trying to undo your engine bolt... but if I were you'd I'd just leave it alone.
If you were really 'orrible then you could clean it up and stuff some of that 'metal epoxy putty' in there and paint over it... it won't do any structural good but it might look better...
Re: crack
Post by ANDYC on Sun 13 May 2018, 11:23 am
Is this a good time to plug my stainless ones. Very Happy
Re: crack
Post by eternally_troubled on Sun 13 May 2018, 11:39 am
@ANDYC wrote:Is this a good time to plug my stainless ones. :D
Yes, I'd put a link to the other thread...
http://www.cb500club.net/t4612p25-stainless-engine-mounting-bolts-and-alloy-spacers
Re: crack
    Current date/time is Fri 22 Mar 2019, 10:19 pm
