I guess this one looks the job - https://www.amazon.co.uk/MOTOPOWER-MP0609A-Waterproof-Motorcycle-motorcycle/dp/B01DT7LI56/ref=sr_1_2?ie=UTF8&qid=1525347062&sr=8-2&keywords=usb+motorcycle+charger
But any recommendations let me know
@fgclark123 wrote:cool. how was installation? big job?
Have you had any de-charging issues caused by the usb, what with the optimate?
@fgclark123 wrote:gollyg, I'm an utter plank when it comes to electrics... and most mechanical stuff! Ahm, can you clarify, if I'm just charging a phone, what's the best thing - wire in a fuse or not? And what's the issue about wiring it all in direct to the battery?
Thanks a lot, need to get this sorted. cheers
@fgclark123 wrote:Thanks a lot. So presumably the fuse has to go right near the +ve terminal, to absolutely minimise the chance of the wiring between fuse and terminal touching the frame - that right?
In answer to your earlier question "Have you had any de-charging issues caused by the usb" A USB socket does not draw any current when nothing is plugged in.
@eternally_troubled wrote:In answer to your earlier question "Have you had any de-charging issues caused by the usb" A USB socket does not draw any current when nothing is plugged in.
A well designed one will draw almost no current when nothing is plugged in; a baaaaad one will draw more. Best to measure the current draw with a multimeter and make your own mind up. If it is more than a few milliamps when it is 'off' I suggest that you either connect it to a switched live or disconnect it from the battery when you are not using it (luckily this is easy as it has an in-line connector).
Hi Guest!
You have posted 0 times since your registration on
The last registered user was http://www.cb500club.net/u2778. Say Hi
Quicklinks
