speedo drive woes
speedo drive woes
Post by Jameshambleton on Sun 29 Apr 2018, 1:50 pm
When I had the front end of my bike apart yesterday I used a solvent to remove the bad grease in the speedo drive.
I removed the red drive gear and re-greased it. Since then the speedo at best at maxed out at 40mph and it jumps up and down even though my revs say I'm doing a steady 70ish. Upto 30mph ish it's fine for the most part and anything above that it doesn't work properly.
I've restripped it today and all the drive teeth are in good order with no cracks ect. And the drive spins strongly though once the speedo cable is attached and it is in position to lead upto the clocks it sometimes stops spinning even though the wheel is spinning. I've removed the speedo cable and it's well lubricated, in one piece and spins easily.
Any suggestions?
Re: speedo drive woes
Post by Jameshambleton on Sun 29 Apr 2018, 6:02 pm
Got it sorted, the piece of pressed metal that sits in the wheel had gotten bent so it wasn't catching the speedo gear properly. Bent it back out and now works perfectly
Post by teamster1975 on Mon 30 Apr 2018, 9:46 am
Well done that man.
r1ncew1nd
Post by r1ncew1nd on Mon 30 Apr 2018, 5:39 pm
Glad we could all help James  Very Happy
Sometimes a problem shared..........
Steve
Post by Jameshambleton on Mon 30 Apr 2018, 6:45 pm
@r1ncew1nd wrote:Glad we could all help James  Very Happy
Steve
Laughing Laughing Laughing Laughing
I usually end up figuring it out, at least there's a solution now
    Current date/time is Fri 18 Jan 2019, 5:32 am
