New air box part?
fgclark123
fgclark123
New air box part? Empty New air box part?
Post by fgclark123 on Fri 27 Apr 2018, 10:26 am
Hi guys, I've found the source of an oil leak - see the oily bolt in the pics. The bolt is mounted in plastic, and at some point someone has twisted it too hard, breaking the housing.
There is a reservoir of oil there - coming back from the engine down into the air box area. I hope this is more or less standard... !
Anyway I thought I'd start be replacing the plastic part that features the dud bolt housing. Does anyone know what it's called? And is it a huge job?
I've got the below New air box part? 20180413
New air box part? 20180412
New air box part? Empty Re: New air box part?
Post by Beresford on Fri 27 Apr 2018, 11:03 am
Those captive nuts are a curse when they sieze like that. However it is possible to repair cheaply as long as you don't mangle the casing too much. Clamp the bush in a vice to take the bolt out (carefully, so as not to do any more damage}. Clean the threads so the bolt may be inserted easily again. Then degrease the bush and housing and araldite back in place. After that always keep the bolt well copperslipped.
    Current date/time is Mon 27 May 2019, 6:06 am
