Front master cylinder needed
Mad_Taffy_500
Mad_Taffy_500
Front master cylinder needed Empty Front master cylinder needed
Post by Mad_Taffy_500 on Wed 14 Feb 2018, 7:13 pm
Hey guys
I need help I'm looking for a brembo front master cylinder
As a screw snap flush on mine when I went to remove the cap to change my fluid
So does anyone have one for sale or know if there is another bike that fits as there's not much on eBay
davecb5002
davecb5002
Front master cylinder needed Empty Re: Front master cylinder needed
Post by davecb5002 on Wed 14 Feb 2018, 7:57 pm
Have you tried drilling the old screw out,would not matter if you had to use a bigger diameter screw.Might be worth a try.
Post by Beresford on Wed 14 Feb 2018, 11:05 pm
A Nissin cylinder would do just as well, and are much more common. Up to 1/2" bore is OK.
Post by Jameshambleton on Thu 15 Feb 2018, 8:27 am
Brembo is a weird one as they use a 13mm bore if I remember correctly as the nissin ones use 1/2" (12mm). If you're really stuck then get one with a 1/2" bore and sell it on.
Mad_Taffy_500
Mad_Taffy_500
Post by Mad_Taffy_500 on Sun 06 May 2018, 5:17 pm
Sorry to drag up this thread
But I still need to sort this as it appears that even though I drilled and tapped the hole it seems to have failed and fluid has been leaking when out when I've had the steering lock on
Post by Jameshambleton on Sun 06 May 2018, 6:16 pm
Check the level of the fluid, but also check the diaphragm against the plastic retainer. Mine didn't seat correctly and it also leaked when the steering lock was on.
    Current date/time is Wed 22 May 2019, 2:06 pm
