ignigion barrel removel
biglee
biglee
ignigion barrel removel Empty ignigion barrel removel
Post by biglee on Tue 23 Jan 2018, 12:17 am
hi all can anyone tell me how to remove the compleate igninition barrell from an 08 cbf my key is a bit loose also  can i use a generic barrell  i think its 2 pin connector but not sure any advice would be most welcolm
ignigion barrel removel Empty Re: ignigion barrel removel
Post by ANDYC on Tue 23 Jan 2018, 8:03 am
Don't do It!
If it's the injection model then your key is coded to the ecu and they're expensive as you would need to replace that too.
Sorry I'm thinking of the 600. It's too early for the coffee to be working yet.
In which case remove the top yoke and you will have to drill out the anti tamper bolts holding on the barrel from underneath. You can just replace them with M8 Allen bolts. Not sure which barrel to replace it with but they are probably easily available.
    Current date/time is Mon 22 Jul 2019, 9:16 pm
