Cb 500s wont start
Cb 500s wont start Empty Cb 500s wont start
Post by wornsprokets on Fri 19 Jan 2018, 5:13 pm
Very cold this morning my cb 500s wouldnt start then a back fire....then battery went flat ...just as well i have an other cb500v....(was in the shed) i think plugs are original ones (has 21.5k) so i change them this wkd and charge up cb 500s battery...some times pays to have two cb500s afro
Cb 500s wont start Empty Re: Cb 500s wont start
Post by Jameshambleton on Fri 19 Jan 2018, 10:50 pm
Should learn how to pump start them, pretty easy once you've got the knack of it.
Post by wornsprokets on Fri 19 Jan 2018, 11:52 pm
Yes ive done it before on cb 500v... i had no time....it was quicker to switch bikes
Also was  bit icy and i had my full gear on too so not too easy to run in.... Embarassed
motofan
motofan
Three's a Charm
Three's a Charm
Post by motofan on Sat 20 Jan 2018, 3:27 pm
James, pumpstart sounds a bit odd, I always thought it was bumpstart.
Wornsprockets when you start the bike from cold do you turn the throttle at all? Engines usually start better solely on the choke, as an experiment try full choke and press the starter with your index finger and leave the throttle alone. If it won't start then something needs adjusting or something so go back to however you did it before! Good luck with it 'cos there's nothing more annoying on a nice cold miserable morning than "no go".
Dave.
Post by wornsprokets on Sat 20 Jan 2018, 5:24 pm
Cb500s i start on choke ...cb500v... doesnt like choke... i start that with little throttle
motofan
motofan
Three's a Charm
Three's a Charm
Post by motofan on Sat 20 Jan 2018, 5:35 pm
scratch Well, one is odd for my money!
Post by teamster1975 on Sun 21 Jan 2018, 10:25 am
@motofan wrote:scratch Well, one is odd for my money!
Probably depends on the state of the carbs, no two will be the same.
Post by wornsprokets on Sun 21 Jan 2018, 10:54 am
Bought run great... but cb500s  alway took 5/6 pushes of starter button...on choke...where  cb500v nearly start on first push of button...with out...with tiny bit of throttle...  yes carbs probbably need clean ss there old bikes now...saying that cb500s gets more mpg than v
motofan
motofan
Three's a Charm
Three's a Charm
Post by motofan on Sun 21 Jan 2018, 11:07 am
Sounds like the v is too rich. Dirty air filter? Choke stuck open, even a little? Jets in carbs too large, dropped out?
At the end of the day they are mechanisms and they should perform largely the same.
Any road up, have fun with them, when it stops raining I want to get out on mine. I know, southern froggy softie that's me   Rolling Eyes
Post by wornsprokets on Sun 21 Jan 2018, 11:17 am
Both cb 500's get used in a three week rotation in all weathers unless theres bad ice...i work in dublin city centre so ,i dont want to use expensive public always late transport...the road salt has give cb 500s bit of rust here and there...but up to last week both were doing great... cb500s on its original plugs so there well over due replacing after 16yrs service...and freezing cold under cover out side so that didnt help either
motofan
motofan
Three's a Charm
Three's a Charm
Post by motofan on Sun 21 Jan 2018, 12:41 pm
My, you do "put them to their proper use"! Here's a mad idea, use the best starting one for winter, mothball the other, polish and cherish it until spring and then resplendent as a butterfly it can once again grace the roads of Dublin! You can then repaint and repair the ravages of winter salt and kack on the other.
I used to enjoy driving the truck in Ireland Cork, Shannon, Dublin if I could be weekended I loved parking up at the Omniplex at Santry and do some shopping and go to the cinema, oh, and have a drink.
Try a new battery I've just thought of!
Soon be spring cheers
Post by wornsprokets on Sun 21 Jan 2018, 10:10 pm
Well cb500s was left up for at least 7yrs and not started...hence 18/19k on it... cb500v  ive put at least 25k on it. Ive an other bike mothballed it fireblade 96 with 24k.... cb 500's need to be used... hence why one goes under cover outside for every day use as ive only a small shed.... omni shopping centre not far...from me
Post by wornsprokets on Sun 21 Jan 2018, 11:00 pm
The cb500s battery is on optimate 4 battery charger...it should be fine...
    Current date/time is Fri 23 Aug 2019, 7:21 am
