6 week mechanics course
fgclark123
fgclark123
6 week mechanics course Empty 6 week mechanics course
Post by fgclark123 on Sun 07 Jan 2018, 10:39 pm
Hi there,
I'm thinking of enrolling in this 6 week course, 3 hours each session, where you get to choose a maintenance task and then the experts help you through it. £250.
https://www.bedford.ac.uk/our-courses/subjects/motor-vehicle/basic-motorcycle-maintenance
It's a great idea - but my question is, what six 3-hour tasks would you choose for help on? I''m a novice by the way. I mean, could I make a solid difference to my bike in that time frame? What would you do?
I just don't know what a 3 hour task is. Engine bolt spacer replacement for example, is one job I'd like to do...
Cheers.
6 week mechanics course Empty Re: 6 week mechanics course
Post by Jameshambleton on Sun 07 Jan 2018, 11:28 pm
I'd say that 3 hours in a single slot isn't a lot of time but I suppose it depends on what you want out of it, as well as your current level.
If you want to check how to properly adjust your chain and checking bearings then I'd imagine it's fine.
If you want to start checking and adjusting valve clearances which uses a shim and bucket system rather than tappet/lock nut then it might not be enough time as shim and bucket also requires removing the cam and then redoing the timing.
As I say it depends on what you want out of it.
Post by ANDYC on Mon 08 Jan 2018, 10:03 am
Engine bolts from our beloved cb's often take much longer than 3 hours to remove.
It's more of a post graduate doctorate course.
In agreement with James the valve clearance would be a handy trick to learn as would clutch replacement.
Replacing the fork seals and brake system seals wouldn't go to waste either.
The added benefit of learning these skills is that as you gain the knowledge of how it's done you become able to teach yourself all the associated things that you haven't really thought about before.
Post by eternally_troubled on Mon 08 Jan 2018, 9:11 pm
Yeah, I can't disagree with any of that.
Assuming you don't mind spending the money then it is probably worth going on the course if only to give you some extra confidence to tackle more difficult/lengthy bits of maintenance.
    Current date/time is Sat 25 May 2019, 1:00 am
