Wind deflecting hand shields?
fgclark123
fgclark123
Wind deflecting hand shields? Empty Wind deflecting hand shields?
Post by fgclark123 on Sun 07 Jan 2018, 6:55 pm
Just thinking about fitting these which deflect the wind away from the hands...
https://www.amazon.co.uk/Black-Motorbike-Motorcycle-Handguards-Guards/dp/B00T9ZEVMU
Any idea if they actually help keep the gloves warmer? Or make a difference at all generally?
Wind deflecting hand shields? Empty Re: Wind deflecting hand shields?
Post by Beresford on Sun 07 Jan 2018, 9:11 pm
Those don't look too practical with the cut-outs and all. If you want to keep your hands comfortable, these are probably a better bet (and not pricey)
https://www.ebay.co.uk/itm/2x-Universal-7-8-22mm-Motorcycle-Bike-Handguards-Hand-Guards-Protectors-Black/262991069569?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
My Tiger has similar guards and they do work well at keeping the hands dry and protected from wind chill.
Post by eternally_troubled on Sun 07 Jan 2018, 9:11 pm
I have had something similar in the past:  it does make a difference but only a little one.  If you want to make a *big* difference you need to get them but attach something to them to make them bigger (so they block more wind!).
The other option is handlebar muffs - they will need something stiff in them to stop them operating the levers at high speed!
EDIT: Those ones that Beresford as posted a link to look much more likely to do the job - so much so that I might buy a pair!
louis_sutton
louis_sutton
Post by louis_sutton on Sun 07 Jan 2018, 11:26 pm
I'm a muff devotee... The urbano muffs fix at the bar end, with plastic sheet reinforcement to keep the shape and prevent touching levers..they're awesome for keeping feeling in your fingers
Llewelyn1965
Llewelyn1965
Post by Llewelyn1965 on Mon 08 Jan 2018, 11:00 pm
I have these exact ones on my cb. They do help and are easy to fit.
@Beresford wrote:Those don't look too practical with the cut-outs and all. If you want to keep your hands comfortable, these are probably a better bet (and not pricey)
fgclark123
fgclark123
Post by fgclark123 on Tue 09 Jan 2018, 10:44 am
yes thanks for the rec, just bought some.
Drago76
Drago76
Post by Drago76 on Wed 10 Jan 2018, 7:32 pm
IMG_5336.jpgWind deflecting hand shields? Img_5310
bar mitts looks lot better choice.
around freezing can driving around with naked hands, and it not fall off from cold.
take in account, the smaller inner dimesions they are, then more warm it is...
fgclark123
fgclark123
Post by fgclark123 on Sun 04 Feb 2018, 7:28 pm
Hi guys, I got these deflectors - https://www.ebay.co.uk/itm/2x-Universal-7-8-22mm-Motorcycle-Bike-Handguards-Hand-Guards-Protectors-Black/262991069569?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
The problem is the bolt that goes inside the handlebars appears too thick for my bars - see images below. Anyone know a way to hollow out the bars more? Am I missing something?
Wind deflecting hand shields? 20180213
Wind deflecting hand shields? 20180212Thanks
    Current date/time is Fri 23 Aug 2019, 7:22 am
