Damper Rod Bolt
Ice-Man
Ice-Man
Damper Rod Bolt Empty Damper Rod Bolt
Post by Ice-Man on Fri 29 Dec 2017, 5:41 pm
Hi there,
I want to upgrade the suspension on my wife's 125, (Sachs Roadster 125), and needs better damper rod. I was thinking to fit one from a CB 500, and upgrade the rear shocks too with some YSS.
Anyway, don't have any stock CB500 forks around the house, cause my CB has a hornet front end on it, and I can;t measure if it fits.
Any of you got a disassembled fork around to check the length, width, thread and pitch of the Damper Rod Bolt?
Thanks.
dougxr
dougxr
Damper Rod Bolt Empty Re: Damper Rod Bolt
Post by dougxr on Fri 29 Dec 2017, 11:02 pm
I'm getting ready to change my fork seals (1994 CB500) so have a couple of bolts to hand. Measurements as best I can make them:
Honda part no. 90116-KV3-701
(Item no. 20 on https://www.bike-parts-honda.com/pieces-honda-detail-1091-13MY5R41-CB500R-1994-F__0800-CB+500.html)
thread major diameter: 7.8mm*
thread lengh: 18.1mm
thread pitch: looks about 1.25mm*
* - Thread appears to be standard M8, I tried a nut on one.
head diameter: 13mm
head length: 5.9mm
Hope that helps.
Ice-Man
Ice-Man
Post by Ice-Man on Fri 29 Dec 2017, 11:46 pm
thanks
    Current date/time is Thu 27 Jun 2019, 4:54 am
