Indicators not working
Scatcat1994
Scatcat1994
Post by Scatcat1994 on Mon 18 Dec 2017, 9:56 pm
Hey guys,
When I click the indicators, they dont light up, either on the bulbs or on the dash.
The electrical thingie (relay?) is clicking. I think it sounds a little faster than it should be but hard to tell.
Cheers guys,
-Scott
pete7mzs
pete7mzs
Post by pete7mzs on Sun 24 Dec 2017, 7:56 pm
I have just had a similar problem on mine, the flashers were only working when they felt like it and the unit was clicking spasmodically. I took the flasher can off which is under the right seat cowl and poured switch cleaner in it, dried it out and it now works every time, Don't know if it was the can itself or just the connections.
Re: Indicators not working
Post by Jameshambleton on Sun 24 Dec 2017, 8:20 pm
Try spraying wd40 into the left hand switchgear, and working them for a while left and right to help clear up the contacts. If that doesn't work try replacing the relay it's located where Pete said.
    Current date/time is Tue 19 Mar 2019, 12:09 am
