Cb500 front brake master cylinder needed asap
Cult classic ad
Cult classic ad
Cb500 front brake master cylinder needed asap Empty Cb500 front brake master cylinder needed asap
Post by Cult classic ad on Tue 28 Nov 2017, 8:35 pm
Hi guys, as the title says im after a front brake master cylinder for my cb500 as mine got smashed off when a lady knocked me off.
Hope someone can help
Last edited by Cult classic ad on Wed 29 Nov 2017, 9:42 am; edited 2 times in total
davecb5002
davecb5002
Cb500 front brake master cylinder needed asap Empty Re: Cb500 front brake master cylinder needed asap
Post by davecb5002 on Tue 28 Nov 2017, 10:14 pm
What exactly do you need ??
davecb5002
davecb5002
Post by davecb5002 on Tue 28 Nov 2017, 10:17 pm
Sorry I mis read that, you want a brake lever. Sad
Post by eternally_troubled on Wed 29 Nov 2017, 9:12 pm
Irrespective of if you want a master cylinder or a lever, we'll need to know if you want a Brembo or Nissin one...
Cult classic ad
Cult classic ad
Post by Cult classic ad on Wed 29 Nov 2017, 9:49 pm
Mines a nissin system. Now have you got one?
Post by eternally_troubled on Thu 30 Nov 2017, 9:35 pm
@Cult classic ad wrote:Mines a nissin system. Now have you got one?
Sadly no. But if you are in a fix then almost any 11, 12 or 13mm (or half-inch) diameter master cylinder/lever will probably make the brake work well enough and certainly make it better than a broken one...
Post by Jameshambleton on Mon 04 Dec 2017, 4:32 pm
Any 11mm mastercylinder will do the job.
Post by wornsprokets on Mon 04 Dec 2017, 6:56 pm
I have a nissan mastercylinder on my cb 500s...think its from a suzuki
Cult classic ad
Cult classic ad
Post by Cult classic ad on Thu 14 Dec 2017, 9:54 am
Sorted an aftermarket one it looks loads better and a straight swap
Post by Jameshambleton on Thu 14 Dec 2017, 12:31 pm
@Cult classic ad wrote:Sorted an aftermarket one it looks loads better and a straight swap
What do you class as a "straight swap"?
Cult classic ad
Cult classic ad
Post by Cult classic ad on Thu 14 Dec 2017, 1:29 pm
It fit fine and the brake hose fit perfect
    Current date/time is Mon 20 May 2019, 10:00 am
