Removing brake pads cb500 1995
MegaChops
MegaChops
Removing brake pads cb500 1995 Empty Removing brake pads cb500 1995
Post by MegaChops on Thu 02 Nov 2017, 6:52 pm
Hi All,
I have purchased a caliper rebuild kit for my 95 CB500 (nisin brakes) so was going to strip down, clean and rebuild my caliper but I've got stuck on the first hurdle. I cant for the life of me remove the screw that holds in the brake pads.
I've tried all different ways, including attaching a flathead screwdriver bit to a socket wrench. I've coated with WD40 and left overnight. I've heated up with a heatgun and the bugger wont come out. I'm worries about damaging the screw, it does slip when I'm trying really hard
Any suggestions or is it Garage time?
Last edited by MegaChops on Thu 02 Nov 2017, 6:53 pm; edited 1 time in total (Reason for editing : missing words)
Removing brake pads cb500 1995 Empty Re: Removing brake pads cb500 1995
Post by ANDYC on Thu 02 Nov 2017, 9:30 pm
The slotted  screw is just a blanking plug to protect the main pin which has a socket type head. The thread is very fine which is very easily damaged.
It would be better to sacrifice the blanking plug than the thread if it comes to that, as that would be easy to replace.
MegaChops
MegaChops
Post by MegaChops on Thu 02 Nov 2017, 9:51 pm
@ANDYC wrote:The slotted  screw is just a blanking plug to protect the main pin which has a socket type head. The thread is very fine which is very easily damaged.
Thanks. Do you think I should just try more force then and not be to worried about rounding it off?
Post by ANDYC on Thu 02 Nov 2017, 10:30 pm
As long as the thread isn't damaged.
MegaChops
MegaChops
Post by MegaChops on Fri 03 Nov 2017, 10:48 pm
Still not shifting, I have it booked in to a garage on Tuesday. Thanks for your help dude
    Current date/time is Thu 27 Jun 2019, 5:49 am
