JamesHambleton 87' VFR750 Liz
JamesHambleton 87' VFR750 Liz  - Page 2 Empty Re: JamesHambleton 87' VFR750 Liz
Post by Jameshambleton on Sat 03 Mar 2018, 8:53 pm
Last update for the next 2 months or so. This little beauty came =D
JamesHambleton 87' VFR750 Liz  - Page 2 Y4miXaQKKmvxsDS1MsvK533U95rtbqvkzUKhUPmA8z53_dho1fyR4rL5RHiiF-xRF7asEEQMQNlnsm8zwS5KaAEPriJMzDWmJg6NkEoVslTfhQoaz6vny6VqqAcUWM2k8UlKBnardxr6g_89puFocnfv5GP3XflOSDs3MH-3awVizJGgJOSdeszxy6z3jdzIxrO9NVzmELGmUJ7_U2MndALtg?width=1024&height=576&cropmode=none
Still working away from home but still busy ordering stuff for the bike.
These have come, thankfully my mums signing for my stuff.
brand new zx10rr 2017 rear shock (finally at a price I wanted to pay)
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mqELaPiNQlnqqVUyMA8nBUKQ0zDBQNLxm4CpdPAZTgb1rkwdIiD6Qnf9QHiE2n5gmeLK4IrrvkB_FiucXO2_mTmn_QPXZocJzCQxwo18bXHPU96wzU3uGRG2UAT8tu7FLVKjbZ66D8SOdz23VbgcNBTMox5azg9MgSuPpcUSaxW6qkijRFRNt2MRmJunzDC0J94zylTB9PqNwD1RquPECSw?width=1024&height=614&cropmode=none
VFR rc24 interceptor panels but have been custom painted but are oem plastics. (still need to get my fiberglass stuff painted).
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mE5sglnLvh2l8NHfXoTL5gWUKJ8sgZXYjNAcrkWaUtPgFgG4EYbvbq1kURQoqrgHO1l3Zvs4zTdH5iPaL8vNnL5YNQvdloz6uH5ViGFDAOGys5n80vH7J9DQzIBFOt-jfghKZ4ywpmNfYMHW03OvJU_jA5r6hAyylcnm3C0WwC0izqstDA5nKA-SPoLW9jczuXnhrC6YEwqPzpdwozaJo1Q?width=614&height=1024&cropmode=none
and finally (for now) the honda wings for the tank.
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mPpkqTlQEgF4NR8-RiBK2sod6y9K3qcaX8eVKtw-zIHHzEYumE14THJQ6GTupFn-1jiX2sYbESX_UuoBnAmeekwZz5EzrWyatVCADo4TaNjBowbtRt3vJbq7h_nVnjo4zCaeHOp1BxNMMQS2JuuKHQDQsTcvHNTymt-EZzvV91olMWk7Qd0aQvEOrTd1xSV0cZhjlGCZHH1JV6cmPYRGH2g?width=614&height=1024&cropmode=none
Still need clipons, koso clocks, fiberglass panels and tank paining and dent removing, offset front sprocket, new chain, rear sprocket, front and rear pads, every single bearing, custom link pipe, battery, then all the machine work for spacers and front steering stem, oh and a headlight.
Post by Jameshambleton on Sun 01 Apr 2018, 8:03 pm
Back home for 2 days.
Yesterday I went to my dads and changed the battery for a motorbatt one. Bike now won't start due to the plugs fouling up due to the bike not been run properly.
So today I managed to get 3 hours while I've been at home to work on a few odd bits. Spent all my time on the swingarm hub.
A massive circlip was holding everything tight, managed to remove that with the new pliers, I managed to prize everything else part using the hammer as it was pretty seized up. Reassembled it with lm2 grease for now, just need to get the bearings ordered for the rear hub once I next get paid. Then the trumpet rear axle will fit.
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mtixEy8TMFwELBqUZHoQym3Wfh7k01UGSKZqep0XWA8bWrwK88E5B30lm_GSqohZNjaeKffLnbhD46BGv0sVFYwJXDUag8u8U9NM0OCyxBAxNmcU03l25vxI6RIq8UurlzczrPYa7MJLNpeEi2KDpoUEmoeXShYXbACXL9MnDZJOtQAbyqK8FgsbfDdqFNmWb92Ghgg3e7rQrSlcATPisLg?width=4160&height=3120&cropmode=none
I've sadly also come to the conclusion that I won't be getting this bike finished in time for the build off. As it'll be hard to explain to someone else (my mum) to talk to a machine shop about what work I need doing. I hope to get home soon between jobs to get it all sorted out as then things will quickly come together I hope.
Post by Jameshambleton on Mon 30 Apr 2018, 11:47 am
Small ish update, rebuilt the rear hub and got the axle now compatible with the hub, thanks to Cookie and his thread for the info on what bearing I needed. I've since acquired a rear caliper that needs to be ultrasonically cleaned, stirpped, painted and rebuilt (got the seals at least). Replaced the battery with a motobatt as it's the only battery I can find that isn't a maintenance one. Got the correct spacers for the front calipers. Need to replace the spark plugs as they fowled up.
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mSZSl8Yn-2BdYOhRpd3u-l-j7-RmBlD5UMZA3DDVpDMKNqZbl_86mbft2wtX_SWtbkTx6qrbAFQTp3L1fje8sXwdVN60iiIynTTSy1zOMVsTk0B9P7XYP8aqoJEkNcbSVhpLOoLmbZzGxpqMYPqcGnYTHP7m7OsPnbD30wkCXaB9wbJBZHYLCE0AnkSlUUfEpxfAjRBDXkK1LqyUyrN4SBQ?width=1024&height=768&cropmode=none
Dropped off the stem and yokes at my local machine shop this morning and was quoted £50, I was expecting to pay about £45 so I'm fairly pleased. So they should be done in a few days.... in which I'll be working away again. dam.
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mlBuGG28SdKtJ0k2ZbnS27V-AkYA2nKNy5ERsvBGAmBaHEdqpty-9QiIhky_6KQ_Mqb5jZKnW8HNPfvdxNx_uDly_crditKyNdwOUP1rI5Oly91pBjrP4s2DW_Wh0bSYSu5FNYLT_SpJCjVfOeGzUzxod7svZYiOaKR1hmgib2fhMEZ4SI_R-eJcszViGU2tNTzRLLz-n3FSg3-J4_2-FFg?width=768&height=1024&cropmode=none
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mYoSsLc-B4O5ZW7_LkWQHkeaMGsIoCe50nl7rawATN71TV6MPoym5MoGQTOkdrsVGCDHxD3yIpVWRxCRXiQJTpK7H8Gi6REXIh46U1lt8Rxk31cP0YpGBYbN9ydmLEJT-hZQq6CkI29e3zt9Vk9YsJX2qzoQfu4YKC1trldR4ugXm_Sp9Lpewx8nVeWm-KFpaMcitpY8V_H7WnsMtLyhZ9Q?width=768&height=1024&cropmode=none
Payday next week so I'll be ordering the fully adjustable clip ons, some bolts to hold on the front mudguard and a few other bits to atleast get the front end sorted out. I know I won't get this finished by the end of the build off but damm once I've got the machine work done things will progress quickly.
Post by Jameshambleton on Sat 02 Jun 2018, 10:22 am
Well with the build off over can I request this to be moved to the member project's section of the site.
Other updates, after I dropped off the yokes with an estimated turn around time of 3 days... 5 weeks later they're still sat in the office so I found another local machine shop and took them there, I've taken the swingarm there.
The guy at the machine shop I'm now using has 3 custom built bikes which are beautiful. They have quoted me much better for the work than the other place too
The clipons I ordered have gotten lost so they're reshipping those.
Oh and I finally got the bike home.
JamesHambleton 87' VFR750 Liz  - Page 2 Y4m5DC9b-_O7mbaik9F7gcUB8W2vIrBZJUZxH9Opw345pkZi1Dg7We3oA2RzuZIdIQCmHEIUfzCfgzNmRFG46d57fqmoCtSBvg472rjM5qlBcJH29q-2JadCOs9reAbSbpVIDdH9svz4VWu981tIVNeeFREvn7IPTfVrRvMw6kIJbXeMxHZMjKSoS0ofmx5yaoCTBVZfoHAAW0DrFJh1DFU7g?width=1024&height=575&cropmode=none
Post by Jameshambleton on Sun 10 Jun 2018, 12:21 am
Moved the bike into the garden not sure how that happened as I'm under mothers ruling not to ride/push/move any of my bikes.. Embarassed
But what she doesn't know can't harm her 👍
JamesHambleton 87' VFR750 Liz  - Page 2 Y4m0blcPgFcZ4rfi8OfiobS8xkhb6JS-1cDTuP9aAkkW5IMWU6Z2BGzRxV0MOYSqSDQmldPSAT5q5HLGX4C7jUuXxbE9QvmaiWRq8b-UbiSYmTSQLj8Ekoph14EXA_r3iAOAe9ApNIAgDE1DYHeQyxDVZO2G08EZvNmyr7sm4yyV3JWWNL5c3uW4eOxghmzX7UhXt95zmoeyUPeSfn0bZRhxQ?width=1024&height=575&cropmode=none
Messed about and fitted the interceptor rep parts
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mOG0POmagE5UkZP-uFKWXG1vwug8LWJJyidTfhbC8Zu_5GwagYYhffyeBNQEt1vojYpxkLx2hvAhdAXbb0K3zWIJJksxUtNvX_qGSbQSNWsJdeTqcr6k9U7SkOMiFS13F7E2zYFmXBm-L99c17thfdpM7q2B7ZMHnvU-tcARcuGjs_eIUqLCrFLFlR_6e-RPBtgNwInFJev2Umorr1ymLag?width=1024&height=575&cropmode=none
Damm I'm in love already :rock:
Test fitted the fiberglass panels that are getting painted for fitment - need to cut out the hold for the rear light.
Managed to trace, mask and transfer the cutout I need for the rear light on the fiberglass rear cowling... it's surprisingly hard doing it one handed but I managed to get it within 1mm of difference. The fiberglass is no where near to the oem panel either so I'm pleased.
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mmZmrzJiwOvYSnlx2QXM-ae0U3DcPLVACznJfvTXspBq2tdgIdREUZikqw_82aFXnztRTVeSmBVAS9V-lbn33OhEeZjgf335xDG4ByDEb9Uil1FkHT2ZeMyhLJuQRm4xYlO3DMy-h5elKzX8u_uoUpEDr_LdfIWpj7YS1_wutjeqyVc_SQQsIIQM0MQHo8nfujViN2oZ5FEEdJry1YjyLHQ?width=1024&height=768&cropmode=none
JamesHambleton 87' VFR750 Liz  - Page 2 Y4m-w_GDr94GvT8y3GMdNrhkvNGEZVT5nP7D-N9GOH_I70weCxztjPckHrPTEt-PnsDxD4nxpXmQuLCXaBOXSRDFhAA1sGHvy2tzCJMI-0hYsLQt7WIxX_0cMMkFdNx4qjjo7W8B6em95TwNzAkxXNSP4oVZsQ6vea4Iu4v0CZLNR9eHBbL-Ovdvm0T2z35qBEH1BCEyD6vRosBQCQeYktwGA?width=1024&height=768&cropmode=none
Post by wornsprokets on Sun 10 Jun 2018, 12:25 am
Good work james...those swiss army knives  come in handy Wink
Post by Jameshambleton on Sun 10 Jun 2018, 8:37 am
@wornsprokets wrote:Good work james...those swiss army knives  come in handy Wink
A wee irish fella gave it to me... he has many lucky charms... to be sure.. Rolling Eyes
I actually use it a lot and usually have it in my pocket most days
Post by Jameshambleton on Wed 13 Jun 2018, 2:17 pm
Well got my pot removed today, so dropped off the tank, sidepanels, rear cowl, rear subframe and rear caliper dropped off at the paint shop.
I've been rethinking about the rear shock setup, since the dogbone triangles stuff not making sense in my head I came across 370steve's hornet thread where he got a bracket welded to the swingarm and running a conventional suspension setup without honda's "pro arm" BS... definitely food for thought
Post by Jameshambleton on Thu 26 Jul 2018, 8:45 am
Got sent these photos this morning.. dammm it I want to be at home and tinkering
JamesHambleton 87' VFR750 Liz  - Page 2 Y4m3x1M_2hDg5DRr_9WBnIycTwie4od7WX4rXwGRSlv5BMrnexxsGreNtkf9sV8dL4URUmEfaqgajCoiSMDGdv4jxwUbHyxXlsYyAdiJZmIq1Av57M3qZcH81FTWIrlShe8lJaDyLbhMfNdmzfcaJwYFIesTFYsEWy8NXNONNhksohwHET4SKRsTbf53rgRY14LILEQTodsngTdi5wYQn35-A?width=1024&height=768&cropmode=none
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mZd9WCNZH6nM2YslmvXrNWwBejhhe3kH9iew0AslgG7oA_biBdSzFvat0oe6GYGHYh55_-uofiYx9-VrOTcIknhd-5VoxxmB38uYqa_eg6yqdfDJyJLFhMEzqqoI4Z-S8nbs2SX7VvW2zLegkOnewHYtj0NPsBGT3AgN9mfuNo2vSOp6Ol2vcvl43y8uhCjZmnNOYlCrUibmbSmehILYRCA?width=1024&height=768&cropmode=none
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mPc_frnuWi7l0zzR5w2KVxi1qhJoLYD-60pkmoprTwLgPr6Za1_L305ZOZO-mSCbHVxVajrVM5y4SKU4DSOTfai3Ww1Zb_CyVWw2PIfhWX6rr9-SuXVhy4XymAGngkrx-CCDEWHX-ZbUkfwHjamQ1x1tp9_eIZKerVwmRF0igIhEW8ATCLBCeV5btu8Zaljis4ZaFEgteMLfRycYT2sHahg?width=768&height=1024&cropmode=none
Post by Jameshambleton on Wed 15 Aug 2018, 1:53 pm
Well I'm back!!!... at home for a few days at least.
Did 3 countries yesterday, it rained when I entered Scotland and also when I left Scotland, I'm sure Yan is trying to keep me out of his country Embarassed
Fully adjustable clipon bars came
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mu7jIDIjjBQAJklimZhkZbKP3DWPa9f32KOyzVIC2TR6LZoeHVFQvks2fxUkxgXn_Nmkuz41XtwvqCV9cfzZr1q48g-vCpwCQKSNcOV0KqZY9TwuadcEz97dqbCVvlloO7zkd2diSZUUdC9IL4_HGTQ7hM1yrApXRxx7bJKPOKTUKypkHiScPvm8Fr8RKmtP20lCGUArVSoS2xluzxEsiSw?width=1024&height=768&cropmode=none
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mCLB4uNvT_xZs59h9_KUkCrE4hqJc10XQSwdzNY9Mh-qRJYzxx94BB3avjGmm93_ZU5_JQZOvBay9Jx0EC82h_dHYgwILgGrmzkeZ1iYOnHSlyw1B2UGfVGBB60Si_xlOsO9D5FKzKtJBsYQR0uCUb0wezye0K4E9lSBTWYQ07M9mbAzikNuibGMojwygHBgBYelR47a5Wq38jHthCX9S7g?width=1024&height=768&cropmode=none
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mm--1yO3JON8K7Oap4GMcUqbnjBsJh-XsWCnYIVVRWVo3Sh1gzvFoObCqXBZi9FzhdxkxAfNcPCpnFIJhullXXnJatqhg2P7HbCJhMu-w5psg0mYcMoLa0GfhuGC_5WZ6z9Us8l1mRWgh1dGwx2RLwtEx5XlRZtA8_oQs0hHx-_623Q6jpcnpqugZynGpuqjyqScI8NcaiHC3LX0NLQc8Zg?width=1024&height=768&cropmode=none
A second update of the day, what is this madness!!!
My mum only started work at 11am and the machine shop opens at 8:30, don't need to explain that any further.
Got the front end out of my bedroom along with rear wheel.
JamesHambleton 87' VFR750 Liz  - Page 2 Y4m6lvn8kKJYt9EqwvwmEb-6nhKctEhtkmT4Xu6LUvyK2aiDWvmWA3sRIQFc5336b7w879hq814u6VU25tgez-Mxme9wKZqvXM-RWGQ9Y2wx4BDEtDxHShHy1IagMgP0Q_C6wfbYmhjSGE1axAtoO4YYFo3xd6xQ-noLwn_1Yk2HoSNfZBu4hyDWLSDZkpStEeyd7mGDV9D5Kf15I2yKzzCYw?width=1024&height=768&cropmode=none
Dug out the rear axle hub out the shed and the axle bolt.
JamesHambleton 87' VFR750 Liz  - Page 2 Y4m0zNWNZ_bSaZcIRli_woGEphu2ba7wqhdJLUh4HZPdQ8lVkMxVqbPZI_Hl8wm4efQZGjHXR8DmrYXNvrMvmRo-cZ47_r4fmoNFPrX-IE2IwZempAWuZttBGu0EeANAA80HcOVOMEVHgK6_5GmLCEtGM4AOt_0XhnYMxlIXJ4e52QhlHK0W1DDZKcv_4yX31Aw1h89mV9izY8d9bgFiAt0Iw?width=1024&height=768&cropmode=none
Got the fully adjustable clip ons but the thing wouldn't nip the stem no matter how much I tightened so measuring time!
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mD5NoEcx6PHNN3hPryRdJu0ZXA3ZYnRQj7M7XuCdRz8CA7hHawPwSmQlNThyNyw9N4zc79GU2PJcJMBwnmoXpTE4FRVRQp25jbtXdQ-AXtZ5YFwIwl4P6TeLfBvGZ4vKQKTeDWsWu-YvSNN4CZ81WeQuRs4edzTYJALqrvJcpgRnRyrd2gFULl0XaQES_MGRtl2sMMXocuzmkdY2_kLpL9A?width=768&height=1024&cropmode=none
Well that clearance on a bit of billet that thick would explain a lot.
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mefr7vYlMsAjJEXnqmcUlPqmz3UBbmcZVjmoZuWSHnvqGPIxcBsi3gzvrSEtFv0M_X93ub3qo2ORuANo_Xk-STrIEeVNLd45MSMlH2lHb_nvmiaM_ckGsZWtUpCBnJuKs3KcvZuMxmYPgy0TE2UcgJVY8DRslYKsLVln4oBQh5ObLfYgEGpOYFi2o5AOowysDBTqnehtyNF4LdqXfMOHllA?width=768&height=1024&cropmode=none
So bodge time... where's that plumbers tape Very Happy
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mqZnnghO9ymEsOZzsLKEmipQVgruqukWIn_MtYTT87UkGMYe9sT7b8BqMazpa2rxl4ur5KGkKj566HaPJ94JUkHYCe5wTC22bDk_SlaYOrsr5jXEq52BzDoaN35lzShWqHx5mHVA7vAa-f-dF1aCDuQ8qzbLxD0EaotEtnOCiSRhZ-lkHt6Z4II8p0RWwxzC663PidDhAP8p-MfBBWoH3Mw?width=768&height=1024&cropmode=none
Mounted up the brake and clutch mastercylinders, excuse the hoses they're from the pond.
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mQo-3z8X8fvLQEj5Z-Y0FUmgdKzteb8tEUwgScqe0FVEo23oLXoh8mVFaoTcF7GrCnH8tEp0IhXVSagqp1IReIYD0XgUzqcoK_CywbayiEGwpimm6weSA08zRhUPb4rdd3WFEZLelzqS0pPmxZ-IBoSmGdqN6kwwJz9g9wgIBrsyNaWuOBiMmeWZQqFXGarmzg_Lv7TmnuBW37I-FQln_dg?width=1024&height=768&cropmode=none
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mldldOpKBkvmG-s_R7F0fGFdrXuBIJSH7X06w_0Dx-90irl0_VNrSJjXGkabTm4cOA3q0w9M18fh50Xl422MHqQTkQ4khRAwvO66KhK7soD3YX_WZ4a8bNg4E3-wANhiQyl8GC9UVu2ohc6S195J4u5HKewrumMd_kQeaJsXyETZmV-pyTZ_mMcyC5Vq1INTCbUKfMvvAEXNGWEx3J6mpww?width=1024&height=768&cropmode=none
Figured the writing on this sign is pretty applicable for when I'm home, a spanner on the floor, a bike in the garden
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mGhRXDi98Xke_alqobZ6Zcin2Ak7sS9cGzFvsPRT72lP1Eux882Cai0z_6wxhxxDD2RgA4Kp9vZ_-hCovDCivA_MPGlD9MzKr6rJu_jczh1haK8cBtExsAXX6Omqztr7dqxBeV2NMq1moHeuANn0659R5XsY_vezcSdWx76gGjMvHuZoRxVJNrOgY902oj9lQeQouhT8mpPDL0xZdQCaGCQ?width=1024&height=768&cropmode=none
Post by eternally_troubled on Wed 15 Aug 2018, 8:03 pm
Very cool.
That bike (with the bit of wood in the middle and no engine) looks like a really cool version of one of those kids balance bikes... Wink
Glad to see it's starting to come together.
ZekeVal
ZekeVal
Post by ZekeVal on Wed 15 Aug 2018, 9:58 pm
That's gonna be a sick bike!
Post by Jameshambleton on Fri 09 Nov 2018, 2:29 pm
Guess who's home =D
so less words more photos
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mCL8wHC_jK_KS21f0IwROGkw_c1ITZPjIHGJSoATz0dhyuz_RjyWARe-9UMi2AZ7Zn_woYyBKGDNSxIT5hcdGxrfLsC8gkbTHJG7JSTdOly8Z-KtXMKbtmCaemnkh3BVjB-ebodUpKysRzNPfTRnPdzCwPUR5Ztat-JQdASYOBGpLFaUyzn2XgCdr_mOydy5-JwoXV2WbtEzIWOdLmzC5QQ?width=1024&height=768&cropmode=none
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mS7g-LDmGg4JnfMkG6LZ2NL_cTEw0sa2Ud4RfawIFhx22ITRcU7YK6A0CMb_qhV8AGQ4bDlxcrPXZhbhKkKmsMvenYdsQxGQZS5H5dk8daim-TWsyPpsHXZ6lKb-5YL9Et-f--p4D3-ulvuAYZLCd4MDTbx3QnQpxAPkKt7-krBsQ4zTyI53XeUB-ILqsWAoiot-xi2mc7Fhs--k04K4Dqg?width=1024&height=768&cropmode=none
JamesHambleton 87' VFR750 Liz  - Page 2 Y4m1UmP3CMnzju3vgqfT2DDl-AmDjlz7Z4LAMkhiNPyfWBqIw4aShHI9urkeKwyNZO7WQ6rImsoXOjA_AUJz-RoLmH23wQtOn8wQLP9gSZlkQOoS0_ZQ-eMFgUQrxfvZ2nOBzkDQJvvbsiX_qPLrKjGARFAFwpyZuM-wKz-E8VDC-EMG5ifMH2Ad6c4BVf_6L-e8sE4KntKLD5OavtZhc2qQw?width=1024&height=768&cropmode=none
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mpXye57_XnyU0RFQRv8Bw7qoG1U_jzSGwE3XkM70Dum0RyrLJR5js2pfZEzAtT9a1T-Idvk7U7RbZ_3RWA535DHeDBijSsfNBQNWt_bV9v_vIiDR42WFpdvH0yiSJXnNU-hL06-_sbk0wOR8Gfd4s_kddg9XuLZBUVEuIexXSlXB51Xm5LJ9DedX6ByKH32deDePsD6od5ISWpqj-JTJeyA?width=1024&height=768&cropmode=none
JamesHambleton 87' VFR750 Liz  - Page 2 Y4m1TZ15krsr1E-HXQDoeFV-ow_ECzo0x3fZtCxrAsrlj2DPo2zmOaxR3gXaq3BJzVNJdIGHzDAmGcmSw0ZfvO29UsW8u5gAysZvDhVVBITfu5mCLuzedL32HD_OSfjiwijIKBdsEcobvcPegGVG_5Nqr89Eb0SMon-arUJyw3Qrq92ex2NioUlTm89sb56A56TVj5PQGvF5ZI8skCKcKnkRg?width=1024&height=575&cropmode=none
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mWFR3HAddNpLNNvAkQ0jjasXzWpDSveqLdgjR5oVOHuazse-gHdDK2iMXZEX40hCeQJjYIw8eQySAwvHsBzG2xfQixyDMzz22H9TK7Vis_ASIRZ0oRzZ8XlxwYCBY3aJlnHoO5fdzsgAo1sP54ytBzYJ50TDxpVR-43ovJsj5M-mbJUylKQYMphPU7XRHzunp_hezJL22SsJ4z9v0CrZ24g?width=1024&height=576&cropmode=none
Gotta go, I've got some paint work to collect =D
Post by Jameshambleton on Fri 09 Nov 2018, 2:30 pm
Well I went to pick up the body work today, since it's been there for - well since the middle of June.
Only thing which has been completed is the rear subframe. The other panels and the tank have only had 1 colour (white) applied out of the 3. He's had 4 weeks of advance notice that I was coming to collect them today.
Not happy as I've had to call in two favours in order to travel up there today. On a plus note he's done a good job of masking the threads on the subframe, overall pretty gutted and disappointed.
Paint job done.. 18 and a half weeks later after I dropped them off... but really disappointed with the decal placement on the tank. I'll admit the size of the decal is wrong by my own doing but it's nothing like the images I sent.
Thankfully I have another 2 spare tanks at home so I'll get them resprayed at either one of the paint shops that [MENTION=20223]370steve[/MENTION] has kindly recommended to me.
This is one of the images I sent to him to copy from.
JamesHambleton 87' VFR750 Liz  - Page 2 Y4m-DagqnPZbn4oNmcK7iPzDiJZ_0tniBaNrEnhhTA5Os91UAyqKLzDGSXE7SXKdKBRQAZUQwvVaR6vDxj-TmA_6ijFocVbsmr0umJox68go3sAE2Ggeel6vdwkucNHPbF2Ga5Wn56hfu5njxCXMm0GwrGwEXXjW1pOIttoSYKZF9sMRih6U0Gf1yh5oU07Sb021NqiO8UL66ENNsXBbpEBaA?width=960&height=540&cropmode=none
Credit to [URL="https://www.facebook.com/dBCustomRestoMods/posts/1751483924959843"]DB Customs for the above image[/URL]
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mgBhBbUKcjec0Gg4etkwRMPY5omc8nZhahNOSrRCWuOmIXmb7aQFFOkoUeGJAIJaAVrsXTBZXS_wgPWRbOH5Z0YBPnB5h7MJP_qU_uQiUlm68X2FPAhz8jddfUz4g5CXRwHLL1ryxRjOWKawNqQwJTsOChvOOfvZRjq_ICGMbtTjh1j6qixV5bZFSQmjw54pS0SlFFtuxPSvP7lC8RMDOvg?width=1024&height=768&cropmode=none
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mjBJdDHfYtvwo6SOWl2q0KF6aq3GKv4_KxIFL5AfrB0VvFHRGUz9bWmxkwHfcq7E4VOor9b04NsXS-LqoAiCKfL5zttFV3P0NONLhb-XOQ6oeHk561LjDpuRkg0Buzbvs0y5RFFRUWGQnmDWuhE8Rs0_xGhnl-IG55_3D-Od56ELY4Ash0s5PJxrcAOMjnlTkkbtzC3Sx02MC3bxDRM4ojw?width=1024&height=768&cropmode=none
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mkCSlz6s8HRvKAj9adtvs1kiMdsni9lAsUuXDOG1G6D0tyPWbqPp0qXSSzlF3kBbuMgF5YQlFvIaySbmcOwCNU3875mB-mvtEI7__LNXuhiDPmdWkTTQEIm9MwzI_rkQrLP25STLwneqI9HgU5S7yrO_nkBEVEXaqM-0C0AHGM6Ml3zKo4jghilYdlfE8p7tG3TMp2W5KXjBqXirFF5NFmg?width=768&height=1024&cropmode=none
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mLaI0YJbrkGXKcdsbp-upfT6psF66tvrpIA7ki5s8TNlzHjQevy8Rm5ND3-Ev3TX1C_D3AwZzZdM3NzWYpFtel5YndkZRlPhNyZZfMCJotYz4hg5CNWQc5lpB6quUEDRo1-xHHY29Ok14xziex5pscjfyGVdFjxE2lVonLV22ktuS8rhiXeo9tvef-HyqYNY8iLvJ0bLygKGzViDP7Dvc8w?width=1024&height=768&cropmode=none
JamesHambleton 87' VFR750 Liz  - Page 2 Y4m0FNmzeygfch7nuVv63wwU4YCIi0y26pDzDqMXY0yHBhsENal7UJbKJ3DYOU_dPluxHTAa8YHaxs4zaTGW54LKNYfV-1w0zmRaNiLRZcDBQgMhzflvLNz5KnXRiVOzQIbD-HZoMJT2CQXyEBKfLmFnPpz_AIrFogxUF2nMvQ3UUaLvGcIUeTwdAUrgR1JTw6dOqqip7366ce1MrGT5de2wA?width=1024&height=768&cropmode=none
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mBehpBQGxEkrw63NRZy6NqfbV5i0-sNlLi130LEvoNc7T3AoQUVxDzmP0MkFSroi9-e95QszkzbebAwLQWkXFOxMShFmnFJ_3tKbyaj1hxBA1XuH7j_WUNn8yf5fEOt1S8mPOXYA0LjYwUn3d3mgT31guC6QjdHNnFurjqqmFP3r93MfwMvgE3e0Q4mRdqtzwvHYXPjcpVYnNzVXIeolP6A?width=1024&height=768&cropmode=none
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mwmRlGIVsud_qJRTX0ghZJeyW1Qkf7kWq_7UOweoFtxe7o_vXyhr8-GdzzKAm0NwY5IsHl0s6z1UNxTkWXr_qiEhvQzuJypHFTJtneIw1PuICaXERm75FHpgi5VycK8focluPGjKEwQNYVsUQ8ImTK-MoH2KN25gB-6S-LmkANmulA5qXOp7kc1KWrVacsIf4ch6pSwAP4WptMrCFgvLu8g?width=1024&height=768&cropmode=none
Right so... updates.
Paint done and collected. Still not 100% happy but I didn't want to wait any longer so happy to have it back.
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mEZO9X-sAQBDShtJO9_eXxqEYa8yczgwO07ugrHHs7xKKd4IkAHZ1yT9JWa7YEKbLFhRlmk9iZH7JapiYJLNAWfuMGXs0C_SUhqQbJ7x7bk0HvK6ugt3I3O3g0OLeR7tK-1dcXNSR1cabpIe-CLX4EaYxulxDAeEBaOct7xqQmi6kcLuT8p2xwSZqrNB5-9dwfnrdTMblbIPN48WqberJ8g?width=768&height=1024&cropmode=none
The headlight and the 50mm headlight bracket adapters came.
I'm liking the little led ring on here.
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mglzMzUJe1agjDRyW2hIrGmrexco-eWH1xOZFe0lEjjEUO3Gel2ips6ehQhBsUJ3mN_mdb5WxfP1Q50LSQgzQGZDlhOtowlVdk-n1_JdgO0cw9b2gK67KtCCbMIYIrs_WTc8HqnfTj9Pig8fdDfnwthftq7Yo8RDRfj6uLyB5GmXJd9Th_RKymGwqCPNGIypBm-2q_3AY_at-3IEL22j1bw?width=768&height=1024&cropmode=none
Doesn't stick out too far either which is nice. Should look much more at home once there is a set of clocks ontop there.
JamesHambleton 87' VFR750 Liz  - Page 2 Y4myJBBRDo-Q4KyCxnhEwXztpbw_CniifUEtoQRLo3Q7iUSfKYlD3LNj2exmaKVMhnxdTmuy_yOxUx4PmzZBD6uaU4rXwUvh1KfxJev050kqviR-KEHEWwclppGGy1vQOeWGofU6BopDHqojA5PqtjXQkY7s41_AK8NoQ694gXdh9PPwf3UpwKqo-VJz66Bvw5g46q3Ols-Ygg60DUMkDGXSA?width=768&height=1024&cropmode=none
As I said before I needed to pass my full licence (I'm currently on a restricted 46.6bhp licence) Well I bought another bike to do my tests on Saturday.
I've been lucky with the availability as they're usually booked up for months. Today is Tuesday and I've passed the first part of my unrestricted licence. Hopefully I pass the second part tomorrow morning.
I've finally got the copper shim shorted out for the adjustable clipons, Nothing a little bit of Cookie's "persuasion engineering" with a bit of wood couldn't sort out Wink
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mQAl3opn6AFecwntK0tAwhbHjaP4yEgHXfg7c-QQ8CZwH54tI8j-fMVFVPBHSDKbx6LOSQV4DBn22dvVW9mkObvhSetM3pkGVPXE2g0hBzOLcXH4krGUlyDZSAIaBYtRpYTVLjMIavpKHydJSam5J1fKSxTKdmZIGDluvMq3r2ynJFM43W3XR7sXd3329gaJid06G9wVTx4FE32FN2kWVWg?width=768&height=1024&cropmode=none
I'm undecided what I should go for on the rear cowl.
Cusomfighters, skullyknucks, both or nothing
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mAyX0t5wpBbC2CyxORAVLow-c9ZZIfzi5QRNC-VWW_MoE73yvRffHpO2TvwgY5_m7Pxh3o35hjHkvOZTuPJIv9fRAu0zQcyY5W9gmGDjNLatzDzq1Xt45SG8bDVQP_Kb-x6UZ0H-J8c6A55He16N_g2NUdGuC8waUvgKafQKF_hC6hhy2koPszYCxuwjKu7M8PLt2O_NgdWe4XTd-d09Gcg?width=1024&height=768&cropmode=none
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mmtRL6HKmR8LGEAL7VfQtA2ThFJJ-LP1ck7WgRL43myQIlhOW1qdXcOVJEgkThlXeN1M2p2WNaqteUFSu5J4zQji2xpTfFak-b5-N0B90C83LbzRGORUa4S_almhKTdimmPlVFn1rkU_Hvh4HX_XATfbipknqZn9epjiPdAmUKiCa6nfcvBebUtfV2m_wQu_456AbdcAY9Wt_Gd52nCW-7w?width=1024&height=768&cropmode=none#
JamesHambleton 87' VFR750 Liz  - Page 2 Y4md85cG_Orm-RO0otx8xzJn5XoQRAQW7IPq_D_7zRqWyoK3QxgAXSm_L6WITZXSsIbee6YpT0PBW1mlmSWbP_8rNniTIGc_QkjdAO_l1mxsJ7TWxaaoDiU3jF19-ooR8h8v3b9IL8JcX6i9mLNnn-ECZd5VC-11EjqizpVecGArnX_TaKZr0mdaFPD1CWW-8qGk1u4YTQHDfrlZZ8upFNMUg?width=1024&height=768&cropmode=none
Post by Jameshambleton on Fri 09 Nov 2018, 2:31 pm
Wow so it's been a year to the day since I started this thread.. definitely not done for the build off.
Other news, I've now got a proper licence passed my mod2 yesterday- none of this restricted horsepower shit anymore.
For those who don't understand the **modern** E.U system
category A1 licence is for people aged 17-19. This restricts you to a 125cc bike
category A2 licence is for people aged 19-23. This restricts you to 47bhp
category A licence is for people aged 24+ or to A2 licence holders who have held their licence for more than 2 years (me).
Each one of these tests has 2 parts, mod1 and mod2. Mod1 is slow maneuvers, mod 2 is on the road. I've had to do both these modules for my A2 and then repeat the exact same tests again but on a bigger bike.
Very little I can do now myself really. So decided to test fit the rear cowling cutout worked for the rear light - works well. Which meant moving the bike off the lift, though about 9 months of shite from outside the shed door (took a couple of hours alone) just to get the bike out!!
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mxfsYQXddOVRgetzjkoiyA0ATNfnqwMOts4xRB8q6r0ixka2duPEKu_wNOLPP0XYlhrlfDcyqtW5utEh2plJ7-rXoeBeqDZ3aixRMU7O0kcC5qgexXlrq7xJwRJeT_YCna3128WdlDpACNwrzj7A4ZhzsZrwqoP5pk3XE5FZXttC0xekhm0jEmAYPC06zByW3EFj7toiRJWWMyIrO-VIHBw?width=1024&height=768&cropmode=none
Wait a minute...hang on..
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mEqlD-z5Nn_bDtKPoQ-jtSpx3_GTzIeK0VRKtJa25O9NsZ02vjUDiMDzJWeH_0EgbvWmPaQzW4_sNVDf4KcLwmY5XsJ9DnVMOIE4cEkVpFg7GhPx2maSxp19likGY5IrOgiGE0rtfw8dnv_g8uNKz8mWBncmrnmckyqpkqxGokr8-fjxWopW0p70NPwA27ygbmTxtmJ6tR_Os9aG5z67cTA?width=1024&height=768&cropmode=none
Ahh there we go =D
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mV8K72erWMM314IPSJ2827Q3shaaXdGsVUg8RgwWFo5M5bAg42xExp-B9l0Zehp2yKjUsuuDLz4RYfXfdtVqh_ittuAl1d1VG1dEaO-zcb8dqUqW6bN74Dgud-9hwQIuhdk7UGvTl1RHmD-OlT0sB2ZUhMx7KxYiRFf4JuppzPnzSlcMsfiad9oDuXVgwIhE7_w93FvTmQeDBqm1_mop0WA?width=1024&height=768&cropmode=none
I'm happy with the front end - so much so that the fork clamps are almost identical and the bars are about 25mm/1 inch lower than the stock. Over research on picking the length of forks paid off nicely.
So my current list is from the front;
Correct size wheel spacers
swap the front wheel round so it's facing the correct direction
custom fork stops maybe cnc bolt over the standard ones? £££
2nd set of 50mm fork clamps for the headlight
Clocks and custom bracket
Drill holes for switch gear(s)
De-rust tank and re-seal
Offset front sprocket + chain and sprocket kit
internal spacer for the swingarm
Rear shock linkage
Custom seat cover??
swap over the rear mastercylinder
measure a brake hose long enough for running through the swingarm
re-rust the rear axle + nut and buy socket to fit the damd thing
Test ride
Strip back to frame and rebuild
custom exhaust system
Post by Jameshambleton on Tue 20 Nov 2018, 2:45 pm
So urm... MOT passed yesterday.
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mBKiGf4JkbYPFu0uoWvOhOL4YiTEQnCX_1bGUJHY9Rjl2VCn6mLyWDn_jTrUQPr4pe_I856hn8m-M2FxxIhKVYeTDGRbwqWvmvMvMVu1CTzNiigHaBrROg04arNpddZX5CXPvkkgQYrnkR5X8zr6iM4FPQUzpo80Zv5pNV2kvA_PR5nq5BSjN5ulYvb3vhhFSjzJaxFpLrJcFuYsq-4Efvw?width=660&height=495&cropmode=none
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mnxyaLgyrXWwOwVojiHy6A8rnkBsqsgZImPLa066vMRtjTxn9FmNY-4l6zb6rUKAPnRxM3_3GRgbeHfBrwdEagw-DsZ4UIZFlV4Ub13OlxEd13Wzdb9ePmWz5keDFOLKWJh44-v-JyCSl0iJJm4qU0tXU8rMdVeKxzBI6WeOWXkjRK968ITJqAxAYdWtQspNCNV8P4AK7juporL2M0npFiw?width=660&height=495&cropmode=none
Onto today...
Didn't get a before pic so look at yesterdays
Today after I started it started pissing down.
JamesHambleton 87' VFR750 Liz  - Page 2 Y4miKOZaFsjMSKt-89uEPD7Y--OzewgruvatKQWq_whVC5N9h1-xTQmiZiEvmCNcb3Ww81csWUHEz-Yz1BxFcr8hnMO1BXF7PYhB0xd6d6p2hyyQiHvbRLEpxSoTWVk130gzBXIQx3-lLbIte2Khjmu9Dcp2By7XbBguOyG7alfEmg3lpVtRQ8O_vqWqmqd6xvzsAJ2sp6j_wTl_VXDAuMIqw?width=660&height=495&cropmode=none
Progress must continue though!
oh bugga blind bearings with no race to get them out.
JamesHambleton 87' VFR750 Liz  - Page 2 Y4m39r0n01cfLMFVKOvwn1CXwdTwHfRDjjQkRP_523edRRc_8qzOKH0FE47LlYMX7q-42XAE1Mr9vssdSppZQr-xhSsClaO_Cj1zhZEYT5krjzwbYcuJaYdOd0-93EeDFWW1dPYVINPMuXILbbWmZ9lPPKU_E8-DY9GvfGj_sd2RXvTQu9Xvo32c2C9Fd0zJyquJi_SRZFtmPgarL1hIvLT2A?width=660&height=495&cropmode=none
That was quickly resolved with my MIG welder.. probably shouldn't have been wearing my brand new Dainese jacket though Embarassed and the front end as almost in... and bloody clutch switch. Slice.. bugga
JamesHambleton 87' VFR750 Liz  - Page 2 Y4m97JdJoCesJzX4dgSknvOt6NOE3hQz0eyxo5OVMz3JhbLruRufKjX0aRGHM3vR6Cfot5A0CXdbEz5_8_gBtllWIWyK_Ke-S5Xh_EKgoM1FT17vjRdOEmJTxSPQRXiOhzcJ49JaD84Abe0jqV75n6JLcPqa3sms7D_uty8uHuSjHAF4LR-hlBl22sVMfH8EJn2Db1YsV-CfAgePrFfvE66pw?width=768&height=1024&cropmode=none
Getting there!
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mcxPaw-eWButMkTYR1u12vCqLG0LSR9OFfdMDiWcRccp7dDCii_iFAqZXhqk_1mkec8XkeC6LEtModDJ7VMobC5gc-26r1A02fo3BT3DRqE8btmUVc78qiznAKCd0X2w3b-3nRWgmAqTGxGSvF09sALf8dlE5KMZU3Cqxt2q6di77sMXzoQt-BqxgP6m8tqm87WMID4WIXGi78ExiT8in3g?width=1024&height=768&cropmode=none
Well that's not going to fit in the headlight! :CK187: but not for today!
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mWhucoMRfVn4lCsS81SizvY1w0Wd9cM820LbOdV0ypxfn8rV6vAFr_myY5bXiSScArj02OAMSN-k9u7IwvEJwuL60YGb8J10o-h-CIgC83SudOP4A0JvgszJOAdruuAYRJ7Kzrkf50s3Xn5nP17w5qSe0U_THFPCd-3kdfzcnuhPpg0Nr8zvostDASvB4TC_5-vpKnhk5MFqEZYW_MgqLog?width=768&height=1024&cropmode=none
After some more fuckary of the top bearing coming out and trying to hold the front end steady enough to get it in. it's in and now for the lock stops.. oh bugga that's a rather large gap!
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mZEiPRcyAOeVC1R6Ka1i-SbNydPTZmYtYp6yZe-iwvv3pnAc6zfe-2Nv7raCmINhxx0lpmPwwwLwqYw9yohvj4MIvMq4gwrQ-hMZ0lh3XlKFNP2pAJ1FjiWZs012Vk1hTH7Oi2PKC7WD9QJNjEkQ5IEJR7PHOTlZ40dMT31HumtFHLa_nLIK16-z6Kb3w5dNr_OLFxCzCrK62sivNe4a5tA?width=768&height=1024&cropmode=none
Was just giving up because of the rain then decided sod it. Basic electricals back on. Front tyre inflated, side light plugged in.
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mbKhh3wQEGt4ip43T_DZQ_Vu6muK7f0VTH5oAPX6Ar40bykchD-7JM-TDOfzaCIPwct2XpLD4AO73GuucQLtaR0yQtQtMnHbahwxZkVUNzuzDiK3Gq2g4MTLeA_AIfb_AjzeBEkX3ogmaIwE_MZRl-HdDgRucQW0A96px4jjV8cUYn_sI9UCBqi36MbCEM4PcE4qEDg-vcip5ictA4nS3GQ?width=1024&height=768&cropmode=none
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mvKWEeuCGtx2ogmkdVB5_cSifn4HjHF-2dO1pofFvwM-_4mo56XiaoLRRz-GjX7voopOpkgL-jnI6nl_UkOq_xBhgjYZxLD_c511KaC3Mx5VZKna2lTx9tNnem8bY--eOZQfL7QYYGvtF3P5kctcZlxVI2eLl0RbqG6lf3kn2v8u6aCls3kKa03ZM11uhjtOogqfZUGDl60-59fXrzMxY5A?width=660&height=495&cropmode=none
Short test ride and there is something affecting the steering, probably too much tension on the bearings, though i'm loving the stance!
JamesHambleton 87' VFR750 Liz  - Page 2 Y4m84wPpmuExhdnlMNrOZoz9PaIjmetg816rK43_ouYbW_jMu65hmliBR7N15eqzF-ZqLonR0SWuDKymz-8NHnrwTuBywr6t0BjJqsi9ztTaA_FYF3rHyF7zys6WW3oI0s21DvDIRpHKqgV0R-Lju5LfP34x8PtUqmfw8O2nsemSfSp91or9W5yV0eeSpTciER1TBoXDbYw3zkEI66J6u1hYg?width=1024&height=768&cropmode=none
Post by Jameshambleton on Wed 12 Dec 2018, 6:13 pm
Got some metal plate from Steve and started work on my lockstops.
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mH1apCs6jmrYpvkuWzqfSCopKFokybOX8quuHADUfaGFgcYPhT5FXkU2NBdK-iTxr9ji0hGdPI2joz0LYOgb0A90npIAyKk0Rt3llXaZSIRlEJI_HjH8TCGAygPQNLZTVblQZGKWXe-CJzgI2KG8s5MHt7QnMvgvrjDWI_-wl2IVOhU8f6cSn6gSVdED7B6Y4mpg_PHR_9YweFAKXGfSLJw?width=495&height=660&cropmode=none
Found that I can use the old fairing mounting points for the stops. :winning:
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mi78pHJJJ5FDHNkpmj4Z5XwVrF7hXEd4krszmug2Iv360fKx_Mh8kJFZX1jNbEZj-flrDuSnBBdIgubz9SNwCa5Efx5TVf77s9EKJ6tLI_9E2P-Hk5aVK9P4KcvQKCmWHfjSGGCJk7u_geHh_QKCR4r6MoaBVMePTIB8Lv5UYIK0iDLN5rA9u2Z_xOvUexkgpKZzs1vklKRrz9tQYYrhIsw?width=495&height=660&cropmode=none
Then suddenly I sneezed.
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mOxgXUNYZ3Jc_smlP-2ulmWmYsIsFvTmB17pwQ_TXpRogU8JijQoNX__mi__30J8gw3qE2DdEcOga72cj7ssbrL8Wt6GM2Zm2AbUEeu9rVPwbb7Z5buvYJZNsDuGKyE_9eN3d0CBIw6WcsUyUZYurtI0glLJiyvpyspRqt9hFrI49XxrevXzXyj7_qNqAPbnlD63TkT8HfKRPVWbQ5QSqQQ?width=1024&height=768&cropmode=none
Ordered the spacer I need for the swingarm then the swingarm will be going in, then it's the headache of the shock linkage.
Post by Jameshambleton on Wed 12 Dec 2018, 6:14 pm
Attempted the molasses derusting method and one tank leaked all the fluid all over. One tank holding strong.
Onwards to Glasgow and back home..
One of the lock stops have being made as close as can be for now.
The bearing spacer I ordered came and pressed that into the SSS bearing, so now I can be on with fitting that.
Managed to get the standard swingarm out. 14mm and 12mm internal hex plugs WTF.
JamesHambleton 87' VFR750 Liz  - Page 2 Y4mLM2NZQJ3lrliDtybckuSJCqEaYWxeP4KzDv5czWfhfczE6SXzYysNbtYjTfDdPXtv9aOjbuSLFW8rxAZ9UM2x0c276OJBp_NM5SLRg6j4PSt1eD5h31DW3FrTOsFo3oS3TiBk1fDNsYH5XDsj4znHWffg4UIocSKw7qa1WUcrQaFlEawhhAq9VIICtBL5YNMIsLiKGjcfrI_uak3jXPDUw?width=768&height=1024&cropmode=none
ZekeVal
ZekeVal
Post by ZekeVal on Mon 17 Dec 2018, 6:00 pm
Some serious spanner handling going on here
Congrats on your MOT. "Exhaust noisy" Ahah geek
Post by Jameshambleton on Fri 11 Jan 2019, 9:03 pm
Bollocks! Bollocks!! Bollocks!!!
The swingarm I had machined to fit in my spare frame doesn't fit in my actual bike. Managed to trim down the spacers enough with the angle grinder to get it to fit but it's very tight.
As I were tightening one of the swingarm pins in place it suddenly felt a bit tight but thought it was just some dirt in the thread, one entire rotation later I decided to back it out and sure enough it's cross threaded.. piss and boloooockkkksss.
Lets start a new page.. this has too many images on this page
    Current date/time is Mon 22 Jul 2019, 9:12 pm
