Where do I mount my front LED auxiliary lights?
Phil07952
Phil07952
Where do I mount my front LED auxiliary lights?  Empty Where do I mount my front LED auxiliary lights?
Post by Phil07952 on Tue 24 Oct 2017, 10:20 pm
I've just got myself some of these
I can't think how to mount them though. I have a 98 CB500S. The brackets supplied are way too small to fit round the forks, and I do they think the screws holding on the front faring will be strong enough to take the weight.
Any ideas guys?
Cheers, Phil
Where do I mount my front LED auxiliary lights?  Empty Re: Where do I mount my front LED auxiliary lights?
Post by eternally_troubled on Tue 24 Oct 2017, 10:55 pm
I bet those clips are the right size for fitting round the handlebars, so you can fit them underneath the bars like what happens on some Harleys. If you want to fit them to a CB500S you will probably have to devise your own mounting method.
It all depends on how much work/alteration you want to do - you might be able to drill some holes in the radiator shrouds and mount them on there (they don't weigh too much, I suspect).
Post by teamster1975 on Wed 25 Oct 2017, 2:19 pm
How about the wing mirror stems? You'd have to pack out the brackets of course or modify, could look cool though.
Post by eternally_troubled on Wed 25 Oct 2017, 10:44 pm
^ That's a better idea than mine! BTW if you do mount them on the bike then make sure there is some way of switching them off, in case the MOT man takes offence...
Phil07952
Phil07952
Post by Phil07952 on Wed 25 Oct 2017, 11:17 pm
Cheers guys, some good ideas, I'll post a pic when I get round to fitting them
ZekeVal
ZekeVal
Post by ZekeVal on Thu 26 Oct 2017, 8:44 am
I've seen a picture of a CB500S with additional lights in the fake air intakes on either sides of the fairing, the slits had been cut to make an appropriate sized hole, looked kewl and dicreet.
Fair Weather Rider
Fair Weather Rider
Post by Fair Weather Rider on Sat 28 Oct 2017, 3:56 pm
@teamster1975 wrote:How about the wing mirror stems? You'd have to pack out the brackets of course or modify, could look cool though.
Great idea, that's what I have been fiddling with yesterday afternoon and today.
They look great in the redundant mirror stems on the 500s, have wired them to come on when ignition is turned on.
Not posting a picture yet, because the bracket need altering,(and it looks a bit Naff) so that the Led's don't catch the fairing on full lock.
But great Idea Teamster, thanks. cheers
Post by Jameshambleton on Sat 28 Oct 2017, 8:17 pm
Bottom of the side of the forks legs
    Current date/time is Mon 22 Jul 2019, 10:02 pm
