Cruise control aka choke?
fgclark123
fgclark123
Cruise control aka choke? Empty Cruise control aka choke?
Post by fgclark123 on Tue 10 Oct 2017, 11:06 pm
Just a thought - I realised I left the choke on slightly today, and was getting a constant push out of it.
So on a long empty straight country road, I edged the choke on full and maintained 30mph.
Obvious question - isthis daft - am I damaging anything, should I stop immediately?!
Cruise control aka choke? Empty Re: Cruise control aka choke?
Post by Jameshambleton on Tue 10 Oct 2017, 11:08 pm
nope, the choke is just an enrichment circuit for extra petrol. Might help to fowl your plugs up a little as it's running ultra rich with minimal air.
Post by ceejay on Tue 10 Oct 2017, 11:18 pm
Fuel mixture will be too rich, plugs would foul eventually I guess, as well as it being not exactly efficient... I'd personally do without the cruise control...
Edit: James beat me to it
Post by Jameshambleton on Tue 10 Oct 2017, 11:26 pm
Good minds think alike.. so I'm worried about your mental well being @ceejay
Post by Beresford on Tue 10 Oct 2017, 11:48 pm
Excessive fuelling tends to wash the lubricating oil off the cylinder walls and can result in rapid bore and piston ring wear.
Hcb
Hcb
Post by Hcb on Sat 14 Oct 2017, 10:29 am
A question.
If you need to increase the fuel mixture (using a custom exhaust for example) ... Could we use the choke to improve performance
without having to configure the carburetors?
Post by ANDYC on Sat 14 Oct 2017, 10:41 am
Not really unless there is a serious jetting issue with your carbs.
A richer mixture will make less power than a lean mixture as it burns cooler and less efficiently.
The leaner mixture has it's limits as it burns hotter and will burn out valves and pistons.
The choke or fuel enrichment circuit is only there to keep the revs a little higher on a cold engine to allow for the drag on thicker oil and to get a bit of heat to the plugs and combustion chambers. Once up to temperature the choke is redundant. To be quite honest engines are much more efficient these days and don't need a choke in normal temperatures.
Hcb
Hcb
Post by Hcb on Sat 14 Oct 2017, 12:09 pm
@ANDYC wrote:Not really unless there is a serious jetting issue with your carbs.
Thank you Andy.
    Current date/time is Sun 18 Aug 2019, 12:24 am
