Race engine
anukatupats
anukatupats
Race engine Empty Race engine
Post by anukatupats on Sun 08 Oct 2017, 8:20 pm
Hi, trying to find info about hi race engine built but it is so hard as all the race parts are about old Cb550 etc....
So can somebody help me with info about race engine builts?
Race camshaft (high lift and duration)
Race light pistons
Race rods (titanium or alu)
Edge cut, polishing crankshaft
Race carburators
Race titanium exhaust
Ignition ecu..
Any race part supplier.
anukatupats
anukatupats
Race engine Empty Re: Race engine
Post by anukatupats on Sun 08 Oct 2017, 8:22 pm
Motorcycle is CB 500 twin 2000 year
Post by Jameshambleton on Sun 08 Oct 2017, 8:31 pm
https://www.bencoyleracing.co.uk/cb-500-engine-tuning
Post by ANDYC on Mon 09 Oct 2017, 10:21 am
http://www.cb500club.net/t3915-my-track-bike-project
You may find this link helpful.
Titanium or alloy rods would have to be custom made and have a very short life compared to steel ones. As well as being very expensive!
High lift cams are only going to work well if you replace the valve guides with shorter ones as there's not much clearance on the standard ones.
Knife edging and polishing the crankshaft is only really necessary to reduce drag if the crankshaft is heavily submerged in oil, our isn't really.
Pistons, race carbs and ignition are all available if you know where to look or prepared to put the research time in.
anukatupats
anukatupats
Post by anukatupats on Sun 15 Oct 2017, 7:26 pm
Thanks. For info.
Andyc way you think Titanium rods would have short life? Moust nowdays biks all have titanium rods and italians las 10years use them on street prodaction bikes.
They are costy thats true....I first will find how lighter they are compeared to stock ones.
Also if somebody know. How much lighter can be done thondersport cb500? If stock dry us 173kg is that posible to get something under 140kg.
How much is weight of CBR500R rear wheel?....as from visual it seems much lighter then cb500 (2000).
Post by ANDYC on Sun 15 Oct 2017, 8:11 pm
At race speeds they have a short life!
    Current date/time is Wed 21 Aug 2019, 6:59 pm
